[QUOTE=Bill Verburg;6734347]...255/40 x17 is a much, much nicer compromise[QUOTE]
That's what RUF and myself choosed ![]()
Roland 930 Turbo '81 Too many modifications to list |
If I understand the inputs here, I should be running a total offset (w/spacer) of not more than -8 to max -10. Maybe I'm assuming that I have the old RUF speedline ET, but actually have the new ET? Hope I'm not "stealing" the thread here... |
I have 10 ET-15.3 on my 930 without spacers, that's what RUF did on 930 too. Mine are according Strosek (same offset like 928)
Don't know if this is the same for SC's with turbo flares as there are different banana arms
if you wanted to run the Avon CR6ZZ 245/60 x15 you would want an 8.5" wheel ET7, that places the outer face of the wheel ~.35mm more inboard than Jeremy's and the tire sidewall 5.35mm more inboard than Jeremy's to run the 295/50 you would want a 10.5" wheel ET-14, that places the outer face of the wheel .35mm more inboard than Jeremy's and the tire sidewall the same 5.35mm more inboard also note that assuming Jeremy is running a 315/35 x17 the 295/50x15 is ~.93" taller w/ commensurate influence on gearing
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 05-08-2012 at 07:02 AM.. |
In front it varies by year because of the different hubs used, '75-80 930s used 911 hubs and a separate 21mm spacer which can be discarded, but from '80.5 on the 930 hubs themselves had 21mm more o/s built into them. In back the 930 trailing arms also have more o/s built into them I'd need to look it up but my increasingly failing memory says that the 930 arms have ~2.25" more o/s than a 911 arm when the hubs or suspension has more o/s wheels of the same width need less o/s to fit the same
what ET you need depends on the suspension, sheetmetal, wheel & tire width What others used on a similar setup is a great starting point but there are so many potential pitfalls because of individual instillation details that it's only a starting point. My advice once the fenders & suspension is installed is to fit a well defined known wheel/tire and then measure how much further you want it to sit outboard. My other concern which may be a non issue is the effect of increasing offset on the scrub radius, particularly in front. We can assume that what the factory does is ok and try not to deviate too much from there.
Thread Tools | |
Rate This Thread | |
