Highly upset,HELP!!
I recently bought a 78 911SC. The car starts fine at times and then other times it idles rough. It will run well and then just die for no apparent reason. Starts back up sometimes right away, other times after it dies, it has to crank a bit to start up. When it runs rough while driving it will backfire or hesitate and pop, then it runs better. I have replaced the fuel pump,fuel filter, fuel pump relay, distrib cap and rotor,plugs, had new wires on it , distrib signal cable and coil. I would guess the ICU is next right?? Any idea what could be the issue??
Old 04-27-2012, 06:31 AM
Chief Head Scratcher
kerthunk's Avatar
Have you just been replacing parts or are you running tests first? Have you tried checking your system and control pressures? They need to be calibrated and it doesn't just "fix itself" by replacing the fuel pump for example. After checking your pressures (system, control cold and warm, and leak), you need to pull your injectors to verify the spray pattern and delivery amounts. Once all that is good, you can check out the ignition system...
The '78 has no computer control, it is all machine. You need to make sure all of the individual parts are working right. Just replacing stuff is going to prove VERY expensive!
I would recommend picking up a CIS pressure test kit and reporting back here with the results. Also, where are you located? There may be a Pelican around you that can give you a hand.
Good luck!
John Morris
'79 911SC
Old 04-27-2012, 06:48 AM
tharbert's Avatar
Welcome to the forum (un)Happyone. You will find lots of great info here. It would help if you described you car setup in detail and maybe post a few pictures of the engine. The original 78 SC engine has the CIS fuel system. Use the search button and look at some of the posts concerning CIS and poor running. Search for CIS and Warm Up Regulator or WUR, "air leaks" and/or "control pressure". For instance, CIS is greatly susceptible to air leaks in the intake. There are lots "how to fix" threads. You will finds hours of reading and I suspect you will come across the answers to questions you haven't even thought of yet.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 04-27-2012, 06:56 AM
Gary H 1978 911 SC
cracked air box........massive vacuum air leaks
Old 04-27-2012, 06:59 AM
pete3799's Avatar
Is this a stock 78 motor,CIS and ignition set up (Bosch ICU)?
Could be fuel related also.
Got a fuel pressure test gauge?
Did you clean the in tank filter (screen) located in the bottom of the fuel tank?
Pete
79 911SC RoW
Old 04-27-2012, 07:00 AM
airbil
airbil's Avatar
BTDT
Bad ground. Engine will start. Car will run. Car will warm up. Warms up and resistance at a bad ground, probably underneath the car, builds up and kills the electrics.
If I recall there is a grounding strap from trans. to body that is open to the elements and corrosion that is the most likely suspect.
Good luck! Report back what you find.
75 Carrera, 06 CttS, 95 Audi urS6 Avant, 97 M3/4/5, 07 Audi S6
Old 04-27-2012, 07:26 AM
ivangene's Avatar
slow down on part replacing...speed up on reading, asking questions and testing
welcome to the forum!
keep in mind, these cars need work, and part of the joy (or frustration) of ownership is the solving of issues
all the best - post some pics
Ed M
86' Coupe
Old 04-27-2012, 07:30 AM
Brown747's Avatar
..also go through your fuse panel contacts. Replace all fuses that are looking 34 years old and cleanup the contact points on the panel with a piece of fine sandpaper. Also cleanup the pins on the 14 pin connector where the engine wiring harness goes onto the panel at the left rear of the engine compartment.
Good luck.
Thor
1978 SC coupe #1834
Old 04-27-2012, 07:32 AM
theiceman's Avatar
Cold control pressure checks and base CO adjustments after verifying no unmetered air entering system due to craked intake sleeves or cracked airbox.. go from there..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 04-27-2012, 09:08 AM
groovzilla1959's Avatar
years ago one of my 911sc's ran really bad as you describe - it turned out to be the fuel distributor
1980 911sc - Silver/black, Ltd Slip Diff. w/original Sport Seats w/Blue Plaid Inserts
Old 04-27-2012, 09:59 AM
wwest's Avatar
Make sure the battery isn't being overcharged....
Old 04-27-2012, 10:10 AM
zotman72's Avatar
Classic CIS fuel accumulator failure symptoms
Old 04-27-2012, 01:27 PM
I'm no CIS guy, but is there a pickup coil in the distributor? Maybe you can pull it, and check for wear, clean and lube the advance mechanism, etc.
Is the backfire in the intake, or out the tailpipe?
Old 04-27-2012, 01:40 PM
AutoBahned
RWebb's Avatar
recent buy, so what exactly did the PPI say & what tests did they run?
Old 04-27-2012, 02:27 PM
ROW '78 911 Targa
timmy2's Avatar
13 offers to assist with questions and suggestions and no response from the poster.
Guess he fixed it...
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-27-2012, 10:17 PM
Cairo94507's Avatar
He may have a job and family.....
'71 914-6 #0372
'17 Macan GTS
Old 04-28-2012, 06:47 AM
aadrew10's Avatar
Impossible
Old 04-28-2012, 10:19 AM
