Location: Seale, Alabama (25 miles south of Auburn, Al.)
I need front pan install instructions
I'm getting ready to remove my fuel tank to prepare for replacement of the lower front pan. I remember seeing a full step by step thread that someone had on here with details of measurements needed and things not to do.
Now that I need it I cannot find it. I have tried several search's and I find a lot of threads but non of them are documented steps. Does anyone have a link to the instructions or a guide that I can use? I need to know what to mark or measure before I start pulling it apart. And pictures are all ways helpful Thanks Rick
Red 1977 911s 3.0L (27230) 2013 Base Cayenne 3.6L |
This is the closest I've seen on the issue:
http://forums.rennlist.com/rennforums/911-forum/499091-battery-area-surprise.html |
Search "suspension+pan" and spend a lot of time pouring through all the threads. There are quite a few, and you will quickly see which ones are the better ones. I would particularly pay attention to where the suspension components are attached to the pan. You do not want to bugger up your suspension geometry when you do this.
Steve B. 1972 911t 1999 328is |
Thread Tools | |
Rate This Thread | |
