Banned
Driving technique question.
I've been thinking about what constitutes a "warm" engine. I have been unwilling to rev up the engine past 4k RPM until the temp gauge rises to the 8 o'clock position. But if the temp gauge is above the first shaded white area, but below the "8" position, then the engine is warm, but the oil itself is not quite up to temp. The oil is the last thing to get warm, so I'm assuming that the engine gets to temp fairly quickly, and the oil lags for some time until it matches the engine temp.
I would like to be able to go past 4k RPM on a "warm" engine, but do not wish to do the engine damage. In my Audi, if there is oil pressure, it's time for boost. But the Carrera I have to treat differently. The question is *how* differently? Temp gauge off the peg? Temp gauge above 7 o'clock? Oil at normal operating temp (8 o'clock)?
Old 05-07-2012, 07:40 AM
Dublinoh's Avatar
Ohio winter (30 degrees) it won't go to "8" even after a half hour drive. I wonder if anyone really "knows" the answer to this. Curious to read what others say.
Old 05-07-2012, 07:58 AM
twistoffat's Avatar
To be honest I don´t really pay attention to the weather conditions when waiting for the engine to get warm. I have a ten minute rule that seems to work regardless of the weather(Ten minutes at 2500 to 3500 revs). I am more concerned about over reving regardless of the motor temperature.
Old 05-07-2012, 08:08 AM
eauboy's Avatar
Here's how I do it:
'85 Carrera Iris Blue Metallic Coupe
Old 05-07-2012, 08:25 AM
Chain fence eating turbo
eauboy - that is my method too..........boost and all.
The cylinders heat up quicker than water-cooled engines. It's the crank and rods that concern me making sure they are warm and "pliable".
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 05-07-2012, 08:30 AM
I also wait for the oil temp to get to the top edge of the lower white block before I rev above 4K. Judging by how quick I get good heat when the air temp is in the high 20s to low 30s, the engine cylinders and heads warm up quick. However, the oil needs to get warmed up to reach the correct viscosity to keep everything lubricated. The Porsche Engineers must have painted the lower white block for some reason.
'86 Carrera Cabriolet Grand Prix White
'09 VW Beetle Convertible
‘24 Audi Q8 etron
Old 05-07-2012, 08:43 AM
KNS KNS is online now
Feel the oil cooler lines in your right front fender - are they warm? Compare to where the needle is on the temp guage. When the oil lines are warm/hot and you know where that is on your guage, take it past 4000 RPM.
Kurt
Old 05-07-2012, 09:36 AM
Porchcar guy's Avatar
And I thought you were looking for driving tips ...Agree with the let her rip note :=)
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 05-07-2012, 11:09 AM
Recreational User
porschenut's Avatar
I believe the whole point of warmth has to do with the ability of the oil to flow, not the heat of the engine parts. When cold (any time the car starts, regardless of ambient temp), oil does not flow well. No oil in the world flows well on startup. That's why 90% of engine wear occurs during cold startup. Oil has to flow readily in order to properly lubricate parts. The recommendation to keep the revs low is to minimize the damage to your engine while the oil temperature reaches a level that provides adequate oil flow. IMO, that point is the let 'er rip mark in one of the previous posts.
Old 05-07-2012, 11:19 AM
Banned
I absolutely am looking for driving tips. Drive it one way "cold" and a completely different way "warm".
Josh D's Avatar
I believe oil flow is part of the equation and would be consistant with all internal combustion engines.
Another, and maybe even more crucial element to our air cooled engines, is the expansion characteristics. I've read in more than one place, including Pete Z's book, that warming the air cooled motors up slowly may extent the life of the dilivar head studs. Getting the exhaust side of the engine hotter than the intake side quickly will cause the engine to expand like a "banana" and that places additional strain on the head studs and or mag cases.
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 05-07-2012, 12:23 PM
billwagnon's Avatar
I thought the expansion of the hot engine was accounted for in the tolerances, so as the engine heats up, any "play" between parts is eliminated.
I keep it under 4000 RPM until I hit the 180F mark on the temp gauge.
Old 05-07-2012, 01:39 PM
dshepp806's Avatar
I keep my '89 below 4K RPMs until I see 180 degrees F....then it's on!
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-07-2012, 02:13 PM
Taking it apart is easy
Jerome74911S's Avatar
I keep it at 3000 or less until reaching, or approaching, 180.
This is with 20W50 oil.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 05-07-2012, 03:12 PM
porwolf's Avatar
+1 here. I basically keep it close to 3000 RPM's or less for street use. I always wanted my Porsches to enjoy a long life and I was Lucky with all of them. I never had to do any engine work on them and they were mostly daily drivers, rain or shine, summer or winter.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 05-07-2012, 03:26 PM
Racer
winders's Avatar
That's a crime......
Scott
Old 05-07-2012, 03:30 PM
River Rat
Dave 86 930 Fl's Avatar
No warm up procedure. Take car to track and run it, it will warm up real quick.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 05-07-2012, 03:51 PM
AKA SportsCarFan
FastCarFan's Avatar
Quote de porwolf
Scott
I agree. I don't exceed 3k rpm until the needle in the temp gauge is above the 1st white block. The I rev it to the redline every chance I get!
Old 05-07-2012, 06:14 PM
Formerly known as Syzygy
Canada Kev's Avatar
It's like exercise for your car!
Kevin
Old 05-07-2012, 06:22 PM
tazzieman's Avatar
I think <3000rpm on a warm engine constitutes lugging. These are tough motors!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 05-07-2012, 06:24 PM
