OsoMoore's Avatar
Broken Targa Top Locking Pin
While messing with my '79 SC Targa top last night, I split the locking pin. This is the bolt the targa key inserts into in order to lock and unlock the latch.
I think this is the piece I need:
I couldn't find it on our host, however. My locking tools are also rather worn, and only have one side of their cross-bar. I think that probably contributed to the break. Does anyone have an old unused locking tool?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 05-08-2012, 05:44 AM
contact Dan at Vintage Porsche Parts and Targa Tops for Porsche he can help you out for sure
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-08-2012, 08:22 AM
OsoMoore's Avatar
Got the mechanism out! If I am to replace just the single bolt (shown in my earlier post) I need to open this thing up further. Anyone already done this?
Old 05-08-2012, 04:38 PM
Hi,
I just posted a repair idea, have a look, might be worth doing before you take apart your latch. I don't know how to link, sorry. Title is: Repairing Targa Top Latch.
-Rutager
Rutager West
Old 05-08-2012, 05:09 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Here you go Rutager.
Excellent fix: Repairing Targa Top Latch
'85 Carrera Targa
PCA/POC
Old 05-08-2012, 06:22 PM
Thanks for making the link Draco!
Both my car and I have limited computer experience.
-Rutager
Rutager West
Old 05-09-2012, 01:59 AM
OsoMoore's Avatar
Sounds like a good plan. My wife is picking up the components today while I'm at work. I'm also going to try drilling out the broken pin in one of my locking tools and replacing it.
Old 05-09-2012, 05:31 AM
Let us know how the drilling goes; I tried to punch out mine with no luck. I think 5/32" rod will fit well, I was going to just cut the end off of a drill bit and JB weld it in.
Good luck on the latch fix, good thing about is it doesn't stop you from repairing it the other way if it doesn't work.
-Rutager
Rutager West
Old 05-09-2012, 03:02 PM
OsoMoore's Avatar
I rebuilt per your suggestion rwest, and it seems fine. I just drilled one handle and I'm off to the store to get some steel stock to insert for the new crosspiece. Thanks!
The drilling only took me 10 minutes with a titanium bit. The cross piece was half gone anyway, so there was a little divot in which I could set the bit easily. I just put it on my vise and drilled away.
Old 05-09-2012, 04:07 PM
OsoMoore's Avatar
I bought some stock for $2 from Home Depot. A few cuts with the bolt cutter got it about the right length, and then I super-glued it in as shown. I'm going to do a little metal filing, but I fitted it before I glued so I think I'm good to go! It feels a lot better when turning the latch compared to the half-broken handles.
Old 05-09-2012, 05:59 PM
porwolf's Avatar
Another solution would be to use a right size drill bit and cut the smooth end off with a Dremel abrasive blade. Then you would have just the right size pin that also is made of very hard steel!
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 05-09-2012, 06:03 PM
OsoMoore,
Nice job, saved a bunch of money too. I'll put it on my to do list.
-Rutager
Rutager West
Old 05-09-2012, 06:37 PM
OsoMoore's Avatar
Originally Posted by rwest View Post
OsoMoore,
-Rutager
Thanks to you guys and my smart wife! Its good to be married to a mechanical engineer.
Old 05-09-2012, 07:41 PM
Time to wake up up this thread.. Same thing just happened to my '79 Targa. The tricky part is that the top is still on and in the safety position, so I cant fully lock it or open the latch. @techweenie and I tried all our tricks to open it up without any luck. My only idea is to pop off the handle rosette around the upholstery bolster and maybe I can access the hex bolts to latch mechanism ? I tried with a flat head screwdriver and applied as much force as I dared but I just felt like it was all about to break. Could anyone point me in the right direction? Thank you!
Old 11-03-2020, 05:30 PM
I would suggest contacting Targa Dan at Cars Inc.
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 11-04-2020, 09:26 AM
