how do you know if you have an ignition control unit problem ?
what are the signs ?
thanks
Luc 1978 911 SC targa |
to be more precise : how can I tell between problems from the fuel accumulator vs ignition control unit ?
First thing is to check for spark. If you have a consistent, strong spark, your problem is fuel related.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
5String
When the Permatune in my car started to go away, the car got much harder to start from cold.
5String Tell not a soul that you have seen me; breathe not a word of what I say.... The Northwest Files |
Fuel accumulator test.........
You've been given simple test to determine if the FA is leaking or not in your other post. Test it and confirm it is not the culprit for your low residual fuel pressure (??). Troubleshooting is a process of elimination. Once the FA is tested and confirmed good, focus your search to other possible culprit/s. Have you checked your residual fuel pressure? What do you mean by 'ignition control unit'? Be more specific and keep us posted. Tony Last edited by boyt911sc; 05-10-2012 at 09:12 AM.. |
you have no spark and the car will not run.
if tony has given you advise about this in another thread, do what he says.
Chain fence eating turbo
I believe this was explained in the "MSD exposed" thread on why this happens.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
