New Bilstein strut assmblys- inserts are loose
installed them 2mo ago. just took back the psnger side the other day and they exchanged it, installed everything- nice and tight. today working on the driver front suspension, this one is loose too?! i checked my strut mounts and they are good, top bolt is snug. my old struts never came loose like this. what do u guys think is going on???
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
Lots of variables come into play, but my guess would be the wedge bolts weren't seated properly. Can you give us any more details & pics?
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
na thats not it. the play is between the insert and the strut housing. im thinking the play might actually be my top mounts, but my old ones didnt do it so im baffled
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) Last edited by jason2guy; 05-06-2012 at 06:49 PM.. |
Jack it up , pull it apart and you will find the answer!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
ur right. but pull apart a brand new assmbly? wtf?! so i pull it apart, find the problem and then i have to FIX something thats new- that sux. id rather return it for a differnt one at least once. i get some parts from a really great place in glendale ca and they would exchange it. seems highly unlikely that 2 new struts would have the same problem right out of the box, doesnt it? hmmmm
Max Sluiter
I think DRACO-A5OG or whatever his name is has the fix.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
This is the thread Flieger is talking about with the fix that Draco did..
loose front strut cartridge - i need a cure.
"Charlie don't surf!" |
i think his situation was different- boge housing/blstn insert. these are blstn/blstn. either the roll pin wasnt properly installed by bilstein or ??. the only other things in there are the seal and those "bearings" more like a sleeve of sorts that keeps things where there supposed to be
Member 911 Anonymous
Hey this is WHNI (Whatever His Name Is)
JKDMy issue was the inserts itself widening at the insert's upper housing due to the cap not being torqued properly by PO and over time it deformed it but it did not damage my BOGE housing. If I may suggest, it appears you have not torqued the cap tight enough, you have to torque the HELL out of the cap to the BOGE housing. When I had my spindle fixed at Johnson's alignment Steve Alarcon torqued the literal crap out of it, I was amazed. So when I implemented my fix I took a 2" pipe wrench, placed my feet against the inside of the fender and pulled with all my might using my leg. No worries it can take it ![]() I know it seems brutal but it has to be done. I still can't figure out how PAG torqued these suckers. Jim P.S. did you measure the old struts to the new one?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
u talkn to me? so, drago=jim ? cool
yeah i dont have boge housings. its the whole bilstn enchilada. its a beautiful green!!! its crazy thats its loose. i mean they put it together. ill check it in a couple days to see if its gonna require attn. ur right down the street, we should grab a coffee sometime
Sounds Good Brother Jason Sounds Good
![]() I can take a look at it too if you want??? Jim
abit off center
You need to replace the upper bushing in the strut housing.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
so u think i should take apart a brand new strut or exchange it?
Taking apart a new strut is not exactly a lot of work. Take pics as you go if you need proof of poor workmanship.
abit off center
I thought you just replaced the inserts. If you purchased a complete strut assembly and they are not right then I would return them.
-Andy
72 Carrera RS replica, Spec 911 racer |
This is a good prior thread Bilstein strut inserts wiggle?
I have a roll pin type.
=Andy
