Advice please: odometer stopped working...
The odometer on my 1987 targa suddenly stopped working this morning. Any suggestions on how to troubleshoot the problem would be greatly appreciated. I'd like to take a stab at fixing it myself, if it's not too difficult, before taking it in for repair.
commandant of the compound |
The infamous plastic gear failure. Do a search lots of data on how to fix.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Member 911 Anonymous
Have you done any work prior to this?
It could be several things: 1. connection at the trans sensor 2. connection under carpet on top of tunnel 3. loose connection behind the gauge. 4. broken solder joint in the speedo, it would be the green wire. Where in SoCal are you? Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 05-12-2012 at 06:04 PM.. |
Just save yourself the grief and send it out for repair.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
100 bucks from Hollywood Speedometer.
search function must be broken again ...
and the tech article tab must not be working either .... someone should check that out .... |
ah too bad too far to assist hands on. but check those items to determine the fault.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Draco, can you move to Minnesota? I would like to have you as my next door neighbor ...
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
:d
If the speedo is working and the odo isn't, it is likely the nylon gear in the speedo arfuerst said. As was said earlier, It is about $100 for North Hollywood to change out the gear and this is what I opted for. You can DIY but you have to be very careful taking the bezel off. Apparently zeroing up the trip meter while driving is not a good idea. Cheers
Detached Member
NH Speedo will completely service it for the price and repaint the dial so it looks new, calibration as well.
Hugh |
And once you get it back, never press the reset button again! IMHO, this is the only way to keep from breaking the gears. Car moving or stopped, it doesn't matter -- this gear is WAY too weak to function correctly. Chuck.H '89 TurboLookTarga, 334k miles |
Pure Awesomeness
Mine just stopped working yesterday. I had not reset the trip odometer in quite sometime, and it rolled over at 999->1000. I guess that is just as bad as resetting while in motion and killed it.
I've actually reset mine a few times while in motion (force of habit from other cars I own) and never had any problems. It never once felt like something was going to break.
1977 Porsche 911 |
I have reset mine exactly once in the last 10K miles - it is at 251K and as far as I can tell it has never been replaced.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! |
Here's a thread -
Odometer Gear replacement for Electronic Speedometers (long) PP stocks the gears. Mike
The more I learn, the less I know. |
Fb = M/S
North Hollywood did mine including removing, reinstalling speedo while I waited. Took them 30 minutes including calibrating. My understanding is that the grease used originally breaks down the gear plastic after awhile.
North Hollywood repaired my odometer, changed the faceplate from 150MPH to 160MPH/KPH, and calibrated it for about $130.-. It took them about 3 days. Well worth the price.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
