MFI AFR reference measurements?
Hello all,
I'm about to install an AFR gauge/O2 sensor etc on my rebuilt engine so I can monitor the engine's performance. I noticed that compared to a few yrs ago, there seems to be more experience with this on this BBS now.
So my question is: is there some consensus about which DIY measurements I need to take? For example: one test could be 'drive on a level road, 3000 rpm, coasting, AFR should read between so and so'. Maybe this is a rubbish example, but I hope you understand what I'm looking for.
Any thoughts on this, as it's fine to have the tools, but they're a lot more useful if the measurements can be compared to a 'baseline'
Cheers!
_____________________________
1972 911 2.4S Black on Black, Recaro's, SSI, MFI, dual pipe exhaust, currently running in after engine rebuild!
Old 05-15-2012, 01:50 PM
304065's Avatar
Well, I would first focus on making sure you have the correct mixture at WOT under load. I did this on the racetrack a few years ago:
One Lap of Lime Rock through the eyes of an Oxygen Sensor
Once you have that under control, then go for a part-throttle test like that described in Check Measure Adjust- although that's really more for emissions than power.
Remember that you set the part-load adjustment first and then the idle.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-15-2012, 02:47 PM
porsher
aston@ultrasw.c's Avatar
norm op temp, level road etc...
part throttle/steady state at 1,000, 2,000 rpm etc
WOT at 1,000, 2,000 etc....
part throttle is easy, WOT is harder. I have a data logger so I can download the results and analyze at home. I don't know if you can get valid data with an assistant and a note pad.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 05-15-2012, 02:50 PM
Thanks.
I've indeed read the Track thread with much interest. But as I'm lacking a logger, I was hoping that there might be some pointers of general reference points that would give me some impressions to start with. I recall some threads discussing this, but can't find them.
Will keep (attractive) assistant + notepad in mind
Any other ideas on this?
Old 05-15-2012, 10:26 PM
porsher
Originally Posted by elflamo View Post
Thanks.
Maybe a video of the AFR and tach, then you can analyze frame by frame.
79 928 Race Car
Old 05-16-2012, 09:47 AM
