A/C question on SC
I was in the process of going thru A/C system on my 82,change drier put sys on vacuum pump, leak check and give her a fresh charge of 134. Ran it to a snag, I have not looked real hard can someone tell me where is the drier located??
Old 05-15-2012, 04:46 PM
pete3799's Avatar
front left wheel well.
Pete
79 911SC RoW
Old 05-15-2012, 05:13 PM
Senior Advisor
James Brown's Avatar
did you convert to 134?
08 Cayenne Turbo
Old 05-15-2012, 06:08 PM
Thanks Pete, No I didnot do the conversion to 134A however not really that hard to do. It was kinda a racket thing buy the auto industry 134 operates close to R12 pressures. If you want to convert they make the compressors and you will need to replace , expansion valve in comportment in trunk will need to be replaced. You should replace drier. Recommend hooking system to a vacuum pump and pulling sys down to 500 microns or about 25 inchs of vacuum for a couple of hours. Then you will need to charge system with hood down in engine compartment. You will need to have evaporator pressures between 25 to 35 lbs. Make sure to keep Head Pressures below 200lbs in will very as the ambient temp outside will affect pressures. Charge system only on low side suction
Old 05-15-2012, 06:31 PM
40 to 50 microns for three hours is required to get the non-condensible gasses down and the water out of a 911 system; 25 inches of vacuum being adequate is a function of altitude. Not enough at sea level and impossible at my altitude. Failure to change out (flush at least the condensers) the mineral oil with an R-134a compatible oil is the origin of compressor failure and lousy heat transfer. The desiccant in an old R-12 R/D is likely not compatible with R-134a.
Old 05-15-2012, 07:14 PM
Old 05-15-2012, 08:00 PM
Scott R's Avatar
Harder than you might think on an SC.. To do it correctly anyway.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-15-2012, 08:13 PM
^^^^+!.. It's not a 'racket'.. I would recommend using Freeze 12, if you don't want to do a proper conversion..
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 05-15-2012, 10:46 PM
All refrigerant is a racket and about money and lobbist. Dupont is making a fortune on the green planet. For those who do not want to do the conversion ,MP39 is the drop for R12, as far as the oil you just need to add a little POE oil the reason is not heat transfer that is done with the superheat adjustment of the expansion valve. POE allows for oil return to compressor due to the glide change of 134 a
Old 05-16-2012, 04:40 AM
fred cook's Avatar
A/C hoses..........
The original hoses should also be changed out to a barrier type hose. Otherwise, the smaller R134 molecules will find their way out thru the more porus hose material. When I did the changeover on my SC, I pulled the hoses, cut the crimps and reused the threaded ends by crimping them into new barrier hose. My local NAPA store had the hoses in the correct size and let me use their hydralic hose crimping machine to reattach the ends. The suprise was the one hose that runs from the engine compartment to the front condenser! Turned out to be about 16 feet long!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 05-16-2012, 05:16 AM
kuehl's Avatar
Most "Factory Air" or Behr evaporator systems have the drier in the LH front fender.
Aftermarket or add-on systems such as VPC tended to locate the drier in the RH front fender.
Old 05-16-2012, 06:54 AM
I wouldn't switch from R12 without adding condensers
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-16-2012, 12:24 PM
