cary's Avatar
Sending unit tube fell into tank :( :(
Does anyone have any tricks or experience trying to retrieve the tube out of the bottom of the fuel tank?
With what little I could see it looked like it slipped under some kind of structural cross member. Dandy ............
I'm going to retrieve my snorkel camera and see if I can get a better look.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 05-13-2012, 09:35 PM
porwolf's Avatar
This is how your tank's inside should look like if it is one with the swirl pot for CIS fuel systems. Maybe it helps;
1973 911-T (CIS) Fuel Tank Exposed
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 05-13-2012, 10:13 PM
cary's Avatar
Thank You ............
That is a great start. That tells me the cross member goes completely to the bottom.
So the tube can't be trapped under it. That's encouraging.
Cary
73 914S 2.0 AG
Old 05-14-2012, 04:38 AM
Same thing happened to me. I used a telescoping magnate tool and a pair of very long needle nose pliers to grab it once it was close enough. It was a pain and you have to go very slow with the magnate tool as it will stick to the bottom of the tank.
Also, be careful not to over tighten the little nuts when you put the sending unit back in with a new seal. They snap easily and then you will be making another post...
Good luck.
Old 05-14-2012, 04:57 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Pickup
I made one of these for general purposes.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-14-2012, 06:55 AM
you could just leave it there and get another sender.
206 637 4071
Old 05-14-2012, 08:37 AM
aadrew10's Avatar
LOL. That inspires confidence if I were to hire you to rebuild my engine...
- Andrew
81SC
Old 05-14-2012, 08:41 AM
what do you think it's going to hurt?
206 637 4071
Old 05-14-2012, 09:37 AM
cary's Avatar
I thought the tube was aluminum? Is it steel?
John's answer is a double edge sword. He also has to charge the customer $100+ plus per hour to try and get it out of there. So you a $350 charge on your work order.
So the customer is screaming either way. LOL.
Other than the sound of it rolling around in there, it would be fine. I'm always pushing the cars around my shop. The sound of it rolling around would bug the crap out of me. Too anal I guess.
Cary
73 914S 2.0 AG
Old 05-14-2012, 09:44 AM
Dublinoh's Avatar
Don't think you'd hear it unless the tank was empty and you turned the car onto it's top.
Old 05-14-2012, 09:55 AM
aadrew10's Avatar
I wouldn't want the same shortcuts taken on an engine rebuild, that's all
Old 05-14-2012, 10:01 AM
cary's Avatar
I'm probably at about 5 gallons.
But I was jacking up the car to put on the Hoosiers.
As it came down and rolled forward I heard it.
99% of folks wouldn't even notice.
You're in the car with the engine running when the car is isnt moving.
Cary
73 914S 2.0 AG
Old 05-14-2012, 10:09 AM
vash's Avatar
so the sending unit broke and dropped the shaft portion into the tank? the flange came off? that would be annoying.
it is going to be a challenge getting it out of there. buy some long hemostats
poof! gone
Old 05-14-2012, 12:47 PM
cary's Avatar
Just the cover came off.
Both wires and the float are accounted for.
I think there was some sort of white cap inside the tube too.
Cary
73 914S 2.0 AG
Old 05-14-2012, 03:07 PM
vash's Avatar
Oh no. So a magnet won't work.
poof! gone
Old 05-14-2012, 03:14 PM
cary's Avatar
Successful evening ...............
I got it with my grabber and my new HF camera.
I'm buying an extra lottery ticket on Wednesday.
Cary
73 914S 2.0 AG
Old 05-14-2012, 07:20 PM
porwolf's Avatar
That is great! Thanks for keeping us posted. Where did you get that HF camera?
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 05-14-2012, 09:36 PM
ROW '78 911 Targa
timmy2's Avatar
Harbor Freight is my guess...
Yep, on sale for $99
http://www.harborfreight.com/digital-inspection-camera-67979.html
Were you able to find the plastic retainer/cap too?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-14-2012, 09:53 PM
cary's Avatar
No on the end cap and nut. I didn't even see it with the camera. It must be way down it that bottom corner. At $99 and being Harbor Freight I didn't think full fuel immersion was a good idea.
This was the first real use of the camera. Super Father In Law finally figured out the focus after we were finished.
I do need to add. I also used a couple different pieces of wire to get it moved around. Starting with a coat hanger.
I was also surprised how clean the tank was. All my 914 tanks have always had some sort of silt buildup in the bottom. We're talking 35 years old.
I did have an extra sender. One with an 802 number. Pops up on EBay as a 914 sender. Which is why I originally bought it. A search here at Pelican says 911 and 914 use the same sender.
Still only comes up to R. I'd say there was 3 gallons in the tank. I'll go out tonight and put in 5 gallons and see if it moves to 1/4 tank. If not I have 2-3 others I can borrow out of my 914's.
Thanks for the help.
Oh yeah, the tube I pulled out was aluminum so my magnets wouldn't have worked. I have all kinds of magnet gadgets. But only one 25 year old cheezy grabber tool.
Wireless Inspection Camera - Great Deals on Wireless Inspection Cameras at Harbor Freight
Cary
73 914S 2.0 AG
Old 05-15-2012, 04:59 AM
ROW '78 911 Targa
timmy2's Avatar
So, I pulled my sender as my gauge was sticking, my plastic cap was gone too. Found out a plastic pill bottle cap I had fit perfectly. One small hole, a lock washer and a 6/32 nut later, it all lines up and no binding. Dilled 4 3/8" holes in cap to allow fuel flow.
Gauge works perfectly now.
Guess the new unused sender I bought from a fellow Pelican can sit on my shelf for a few years...
Dennis
Old 05-17-2012, 05:46 PM
