mack6820's Avatar
Thumbs up Clunk clunk fixed!
Thanks once again guys for the best auto repair forum I have ever used. Had a bad clunking noise coming from my drivers side front wheel. After researching on Pelican, I found the gland nut very loose. I was about to replace the bearings and strut assembly all at once, now shes back on the road at no cost to me.
BEERS ARE ON ME!!
Certified Southern Dumbass!
83 911SC with 993 conversion,
98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
Old 05-20-2012, 04:03 PM
SC Ray
81 SC Ray's Avatar
Mine is doing this - What is the gland nut - is it easy to get a photo of??
Thanks so much. I already replaced the bearings....a waste of time and money!!! Still clunks.
Old 05-20-2012, 04:34 PM
Ok, I'll jump on the band wagon too...mine is doing this as well. But my gland nut is tight so I'm not sure what is up. What is the tell tale signs of a worn strut spindle?
"Charlie don't surf!"
Old 05-20-2012, 06:20 PM
mack6820's Avatar
have someone push the brakes while you agressively shake the wheel. This will illiminate the bearing. The gland nut is inside the top part of the strut. You will need to remove the top bolts of the strut, then swing it down and clear of the wheelwell. Pull off the top half of the strut to expose the gland nut. You can tighten it with a screwdriver and hammer.
Old 05-20-2012, 08:39 PM
mack6820's Avatar
found these pictures online of several gland nuts. I wish I had taken a picture of mine thought. Hope this helps.
Old 05-20-2012, 08:44 PM
SC Ray
81 SC Ray's Avatar
That does help!!!! Thanks. Look like a med fix - not a quick fix. Thanks again for taking the time to reply.
Ray
Old 05-21-2012, 07:16 AM
mack6820's Avatar
Took me about an hour to fix it
Old 05-21-2012, 09:44 AM
Thanks...
This may be my problem as well. It seems to occur in a low speed turn - usually over some sort of a bump (160k+ mile SC).
Maybe this will get me by until I source all the parts for a full suspension rebuild...
Old 05-21-2012, 10:40 AM
