Any tricks for removing axle nut?
Hi guys,
Starting in on my rear bearing/CV boot adventure. I bought a very long 1/2" breaker bar and a 1/2" 30mm socket. Holy cats is that bolt on there!! Any tricks for removing? The car is in gear, e-brake on, wheels on the ground. I wonder if I'll wind up breaking the joint on this breaker bar? Mark.
Mark - New Glarus, WI |
Put a few feet of pipe on the bar, yes it's really on there that tight.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
You need to get an extension on that breaker bar. I used my floor jack handle and it still took alot of pressure to break the nut free.
"Charlie don't surf!" |
Never mind! I just went out and (carefully!) jumped on the end of the breaker bar and got both nuts to break loose
Mark. Quote:
I snapped a 1/2" breaker bar, moved onto a 3/4" with a 4' piece of black pipe from Home Depot to get enough leverage. That thing is on there TIGHT!!!
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
yup u need a 3/4
even then u need an extension
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
RETIRED
Always remember to remove the cotter pin....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
torquing to the correct value when re-assembling is also a challenge. You will need a length of pipe, depending on your weight, to reach proper torque. I believe it's ~340 ft-lbs.
Good luck. ![]() Anthony. |
You may want to cover the socket and extention with a heavy cloth/rug in case the socket breaks and goes airborne!
We put a ding in a SC fender trying to remove a spring plate adjustment bolt. |
I think a few others have just gone to a shop with a powerful impact wrench and had them break them loose then snug back up for the drive home where they could be removed without having to risk serious injury.
RETIRED
IMHO, a hand job is better than an air tool....
