OsoMoore's Avatar
Time for another Round... Name That Part!
I apologize if this is too easy. I was working on the Quick-n-Dirty heater backdate (going well, another thread another time) and broke off this wire. What is the part it connects to?
Obviously, I will need to splice on a replacement and so forth, but I am curious as to what exactly it is.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 08-22-2013, 05:50 PM
ROW '78 911 Targa
timmy2's Avatar
That big doing gold thing is your oil pressure sender.
Pretty important in my book!
Just pull off the spade connector and crimp a new one on there.
Old 08-22-2013, 05:57 PM
Taking it apart is easy
Jerome74911S's Avatar
Oil pressure sending unit. Tells the gauge what psi you are running - or how many bar.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Member 911 Anonymous
DRACO A5OG's Avatar
The Druck Pressure on your Gauge, no biggy just re-solder, FIXED
Mine snapped after an AX :-(
'85 Carrera Targa
PCA/POC
Old 08-22-2013, 06:13 PM
Smoove1010
Smoove1010's Avatar
If you get the urge to swap the sender out for a new one, be sure to search this forum for advice on doing so before you jump in. Engine case crackage may result if you try to wrench it off by itself.
Old 08-22-2013, 07:07 PM
