Free minder
Chain noise
Lately, my engine developed a distinct chain noise at high mid to high rpms. It is especially frustrating since I rebuilt it with upgraded chain idler arms and pressure fed tensioners only two years ago. So, I did a partial engine drop for valve adjustment, and removed my chain covers to investigate. The passenger side was nice and tight. But on the driver side, I found the chain not as tight, could lift it about 10 mm from the ramp. And also, the idler arm can move back and forth on its axis by at least 1mm. Questions: 1. How can I tell for sure if my tensioner is bad? 2. Is the back and forth play on the idler arm axis normal or not?
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Free minder
OK I did a little search, and the play on the idler arm is normal. We are only left with a possibly bad tensioner. I noticed it is less extended than on the other side.
Check to make sure the nipple didn't come detached.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Free minder
The nipple is still there. But the tensioner is extended only 7 mm on the drive side, versus 11 mm on the passenger side. Shouldn't they be the same? Also, I was wondering if the tension increases when oil pressure gets to them? If not, then the chain is definitely too lose on the driver side.
Free minder
I removed the tensioner, and I can compress it fully by hand! I really think it is toast. My plan is to revert back to my old setup with safety collars. I still have the old chain covers and the old tensioners, which are very strong. No way I could compress those by hand.
It may not be toast, compare it to the resistance from the other tensioner. The running resistance is greater as they have the pressure from the oil.
I believe that you can disassemble and repair it as well, I haven't had one apart in a while. This would be a good time to bullet proof them by doing the "Jerry Woods Mod". Quoted below for your convenience; Quote:
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 06-02-2012 at 10:10 AM.. |
Free minder
Thanks Shane, I was just looking at this thread. In fact, I already dismantled my tensioner, and unlike the old style tensioners, there are no o-rings that can fail. The only part that could fail is the spring, and mine looks fine. So, my new plan is to refresh them by adding grease on the piston, and do the Jerry wood modification for peace of mind. Then, if the chain noise is stil there, I have bigger problems...
