Conntrol Arm U-Tab. Are They All The Same?
Hi,
Trying to put together my front sway bar assembly. I have a sway bar that is similar to a Tarret product. I have found the U-Tab kit from Weltmiester here at Pelican, but I want to make sure that it will work. Thanks for any help. James |
Yes it will, but have it welded in and mount it so the openings are front to back.
72 911 Although it is done at the moment, it will never be finished. |
Thanks for the help.
Less brakes, more gas!
front to back? I think mine from oem '72 arms are opposite that. Seems logical that they be opposite as well as the rod will be moving inboard and outboard and not forward and back... If you lace them with the open part front to back you may run into interference from the heim joint, no?
-Michael
![]() ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Thread Tools | |
Rate This Thread | |
