Grady Clay's Avatar
Jim (chatas17),
I think you are getting some good perspective above.
Best is:
Originally Posted by LakeCleElum View Post
Jim - You will know the time when the numbers tell you it's time:
Compression, leakdown, oil pressure, oil consumption, etc.
AS usage, conditions, and driving habits vary; you can't count on mileage to tell the whole story........
In its formative years, if your 911 had been “driven hard & put away wet”, it would shorten its life.
There are three important factors:
How it is (was) used (my above “…put away wet” comment).
and
How it was serviced.
A close third is your expectations – it takes regular service (top-ends &rebuilds) to maintain peak performance.
I have some race engines that I completely rebuild every 25 hours of green-flag on-track running.
My street 911 SC is a bit more extended.
My original ’68 911 doesn’t count as it had a fresh (test ) engine too often to count.
Your question is “How close to ‘perfect’ do I want to stay?”
For a street 911, most of us accept something only slightly less than 100%.
I’ll leave the 100% to racing.
Bob S. (LakeCleElum)’s post shows you the ‘way’.
Maintain a history of cylinder leak, cranking compression and other.
This will guide you to when it is ‘necessary’ or simply prudent for a rebuild.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 06-05-2012, 11:21 AM
SoCalSK8r's Avatar
What is the average cost of a top end rebuild?
Old 06-05-2012, 11:29 AM
Registered Loser
Mine has 118K miles on it. Never cracked open, burns about 3 quarts per 1000 miles. It's about time...................
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320
Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180
Old 06-05-2012, 12:11 PM
KarlCarrera's Avatar
124,000 on my 88 Carrera. No issues. No plans to do anything but drive and maintain. Runs excellent, even on top of the Continental Divide.
Karl
88 Targa
Old 06-05-2012, 12:52 PM
E Sully's Avatar
I bought a used 1986 3.2 engine with about 80,000 miles. It was obviously driven hard by the previous owner, noted by the fact it came from a wrecked car. It needed the guides done, everthing else was ok. I did the valve guides, exhaust valves, and rings. Bottom end was still good. It ran great and I ended up selling it to someone for his 914 conversion.
Ed
1973.5 T
Old 06-05-2012, 03:35 PM
Germanator's Avatar
My 88 has 138k miles on it and burns no oil, still on first engine and runs really strong.
My neighbor has the same car but the 89 model and had to rebuild the engine at 80k miles (2 years go).
Even with all the miles my engine pulls stronger than his.
Old 06-05-2012, 04:09 PM
Spiderman
Jesse16's Avatar
On my 87, was burning oil so did the top end at 190K. What I found surprising inside was the amount of build-up in the exhaust ports. They looked to be 25% blocked, been told thats from fuel. I'm glad its all done now and clean as a whistle inside. All the "misc" minor leaks are gone now also.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 06-05-2012, 05:37 PM
Mo money = mo parts
My compression and leak-down were great, but was consuming a quart of oil every 400 miles prior to a top end (guides, seals, intakes, rebush rockers, etc) at 90k. I ended up splitting the case to check everything out and replace the intermediate bearings. Re-ringed pistons too. Running great now.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 06-06-2012, 11:36 AM
KOH KOH is online now
Top-end done at 73,000 miles. I was burning a quart of oil every 300 miles. New valve guides, studs, rings, sensors, etc. - car runs great now.
'87 Carrera, Granite Green, SW Chip, Dansk sport cat, Kuehl A/C
Old 06-06-2012, 02:00 PM
pavegeno's Avatar
Send a message via Skype™ to pavegeno
110k and brought it in for a valve adjustment...two broken head studs fell out when the valve covers were removed...absolutely amazed at how much better the engine runs now 10k post-rebuild. The air-cooled sound is still there but it sounds so much tighter/better and the vibration level in the car is way down...of course it pulls much stronger now...best money I've spent on the car followed by the Griffith's A/C.
Old 06-06-2012, 03:10 PM
I was expecting mine to need it by 300k, but it still runs strong and pulls like a freight train.
Burns a quart of oil about every 6-700 miles these days, I'll wait until it loses power or starts burning more oil...
Chuck.H
'89 TurboLookTarga, 335k miles
Old 06-06-2012, 03:39 PM
196k and dry
I have an 84 with 196k. The bottom is dry and no smoke on deccel or accel. Quiet all through the rev range. Will need the chains replaced as I noticed stretch symptoms once on a really hot day. And love the Motronic over SC CIS especially with the addition of a Steve Wong chip.
Old 06-06-2012, 07:15 PM
Detached Member
Hugh R's Avatar
135K on my 84 no leaks, smokes for a few seconds after it has sat for a few weeks. Uses about 1.5 quarts of oil on a 5K oil change.
Hugh
Old 06-06-2012, 08:06 PM
My new to me '88 is smooth with plenty of power. Compression numbers are excellent -- BUT it burns oil. Get an occasional whiff of blue smoke at stop lights. I would estimate it burns a qt. every 500 miles or so. I knew when I bought it that the valve guides were showing wear, but I didn't know it would burn this much oil. It's got 113K and the (complete) records suggest that the previous three owners maintained it properly.
So what do you guys think: I can live with the oil consumption indefinitely, and I'd like to put off opening the motor until something forces me to (like a clutch replacement). I know that worn guides compromise the valves' ability to dissipate heat, and that in theory one could overheat and break. But that strikes me as an extreme case scenario -- or is it?
I was going to post my own topic, but it seemed relevant to this one.
Thanks!
Hugh
Old 06-06-2012, 08:26 PM
Senior Advisor
James Brown's Avatar
Bruce Anderson, "i have never rebuilt a 911 engine because it wore out"
08 Cayenne Turbo
Old 06-06-2012, 09:43 PM
87 - 911
Rebuilt the top end of my 87 at 100k miles, oil usage had climbed to 300 miles so it was time.
As noted on a previous post, my ports had very heavy deposits that likely choked the air flow 25%. Yours may run for years without issue, but if consumption is at 500 miles then it is just a matter of time. If you are motivated you can do most of the work yourself, will have to sub out the head rebuild to a shop but there is an abundance of documentation available on how to do remove and disassemble the engine. Start reading now and when you feel the time has come to make the leap you'll be prepared for the job.
Other good sources are Wayne's rebuild book, the Porsche service manual and the Bentley manual.
Cost to rebuild the heads will be around $1000, gaskets and other while in there items will add at least another $1000 to the parts total. Go whole hog and the while you're in there items can really add up so be mindful if on a budget.
Assistance from the forum is priceless.
Old 06-07-2012, 05:17 PM
My 85 911 has 140,000 on the clock. Never been opened up and runs great. Oil use is about 1 Qt per 900-1000 miles. Runs very well and passed Cal smog with ease. So that tells me it is in good shape. A well known San Diego Porsche mechanic told me that it should go 333,000 miles easy. Wow, these are super cars. Most cars our vintage have been crushed long ago. But when I see a vintage 911 it usually looks great! Inmside and out. Like mine!
Old 06-07-2012, 05:44 PM
110k on 89 3.2. It was smoking and using a quart per 350mi. I intended to do a valve job but that turned into a complete rebuild. I got curious about the bottom end and pulled it apart and I'm very glad I did. A couple of the main and rod bearings were worn and the intermediate shaft bearings were showing copper. This "valve job" has turned into a new set of Mahle pistons and cylinders, ARP rod bolts and head studs, new main and rod bearings, rebuilt rods, 964 cam regrind, rebushed and resurfaced rockers, etc, etc. I have a problem in that I can't seem to just do the minimum required with these car projects.
Old 06-07-2012, 06:58 PM
Boricua21's Avatar
When I swapped engines on my SC, I was told that the 84 3.2 engine I put in had 70k miles when it was rebuilt. I do not know why it was rebuilt so 'young'. I have since put another 5k miles of very happy motoring.
Arnie Diaz
Braselton, GA
1982 911 SC (3.2), Fabspeed Bypass and Muffler
2003 E39 BMW 530i (Daily Driver)
Old 06-08-2012, 09:52 AM
So why do these engines run so long? The geometry? The air cooled concept? Do the 996's last that long? Just curious. I'm amazed how much pull my car has with 115,000 miles.
-Jim
75 911S targa SOLD
67 912 SOLD
1984 911 Carrera
Old 06-08-2012, 03:47 PM
