86FlatSix
Minor restoration project - Dashboard instruments/cluster question
Hi,
I noticed that there is a hole on the right side facing the steering wheel on the dashboard where most of the ignition switch of non P-Cars are located. I thought this were allocated slots for iginition on a RHD PCar. Please see image with the yellow arrow. What should I suppose to put on there? I'm trying to restore all missing parts left by the PO and doing some upgrades as well. I've done so far is the A/C conversion to 134, H4 headlight conversion and now restoring the radio. The head unit is a Sony and might be looking for Blaupunkts as well.
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
I believe that is where the cabin temperature sensor goes if your car is equipped with the automatic heat control. My '86 Carrera doesn't have the automatic heat temperature control and the hole is plugged with a plastic piece.
'86 Carrera Cabriolet Grand Prix White '09 VW Beetle Convertible ‘24 Audi Q8 etron |
Flat Six
PET says it's called an 'intake manifold' PN 91157252300 and 'clamping piece for intake manifold' PN 911557252500 Hope this helps.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
86FlatSix
Thanks guys! Would you know where to get decent plug ins? Its an eyesore seeing a hole on the dash. Cheers!
There are many cars being parted out (used parts forum). I'm sure one will sell you a plug for a couple of $.
