Go-Kart Mozart
JAR0023's Avatar
No tail lamp/marker lamp right side
86 Carrera
This one seems kind of odd to me, but I'm new to the 911. All lights were working less than 400 miles ago. Pulled in last night and left the lights on (car stopped) and noticed no tail lamp or marker lamp on the right side. PUlled everything out today, cleaned and checked housings/bulbs.
Bulbs good, housings good.
Brake lights work.
Back up lights work.
Turn signals work.
With the car off, move turn signal to right and tail lamp/marker lamp work as parking lamps.
The only time the right side tail lamp/marker lamp does not work is when I simply pull the headlamp switch out. I'm about to dive into wiring schematics in the Bentley but hoped to get some feedback here. I think I'm looking at two areas. The switch itself and the connector in the right rear of the engine bay.
Would the light switch energize the left and right tail lamp circuits independently?
The connector in the right rear. How does it come apart? Just pull?
A search has me thinking the running light/brake light/turn signal circuits are all separate at this connector. Need to dive into the Bentley to confirm.
Thanks in advance,
-J
Old 06-09-2012, 09:55 AM
RETIRED
Joe Bob's Avatar
Mine ended up being a bad ground in the tail light assembly AND the bulb falling out of the side marker assembly.
2012 ML350 3.0 Turbo Diesel
Old 06-09-2012, 10:18 AM
Go-Kart Mozart
JAR0023's Avatar
That's where I went fisrt but the bulbs/grounds are good. The individual lights work when 'Park Lights' are on. They work as turn signals. Right side doesn't work when switch pulled out.
Separate grounds?? I call myself checking this.
-J
Old 06-09-2012, 10:24 AM
RETIRED
Joe Bob's Avatar
Well, I have an 83 SC.....so the fuses maybe different in a Carrera.
Check inside the fuse cover and see if the running lights and/or brake lights have a seperate fuse. Spin in it, check the fuse, and lastly check the output with a meter.
Old 06-09-2012, 10:31 AM
Had precisely the same problem yesterday. Scratched my head for a bit, then rotated the fuse for the right side lamps and VOILA! Problem gone!!
You asked:Would the light switch energize the left and right tail lamp circuits independently?
The answer is yes, they go through different fuses.
You probably didn't notice, but your right front running lamps were probably not lit either.
Got to LOVE those crappy German fuses!! LOL
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 06-09-2012, 10:51 AM
Go-Kart Mozart
JAR0023's Avatar
Was checking fuses while you guys were typing. Bentley says right side park lamps have their own fuse. Cleaned it. Nada. Swapped it. Nada.
Will have to go back and check front running lights.
Remember the lights work if I move t/s stalk up to activate park lights.
It's pulling the light switch where they don't work.
Wiring schematics are mostly Greek to me but it looks to me like the right rear energizes separately. I really don't want to have to go in behind the dash, but I thinly I'm headed there.
J
Sent from my PB99400 using Tapatalk 2
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 06-09-2012, 11:26 AM
RETIRED
Joe Bob's Avatar
Put a meter on the output side of the fuse tab, pull the light switch and then the parking light see if that tab has power. You may be getting juice from another circuit.
Old 06-09-2012, 11:52 AM
Go-Kart Mozart
JAR0023's Avatar
Great tip! Will try that when I get done with errands.
J
86 Carrera
H. L. Mencken
Old 06-09-2012, 12:07 PM
Go-Kart Mozart
JAR0023's Avatar
Confirmed front not working either along with rear lamps with headlamp switch.
Tested that circuit with multi-meter. Pull out light switch halfway or full out and no voltage at the fuse.
Pull the turn signal stalk up and 12 volts along with lit lamps on right side.
Seems to be at the switch.
Also noted that my fogs come on when I pull out the headlamp switch half way. I think I remember this from DRL discussions. Probably put that back to oem.
Didn't really want to dive into the headlamp switch but that's where I'm heading. At least now my tail lamp assemblies are clean and resealed. Along with cleaning all the dirt out of there.
Thanks again,
-J
Old 06-09-2012, 02:05 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Thanks God the banana is back.
Old 06-09-2012, 02:08 PM
RETIRED
Joe Bob's Avatar
So to confirm that the suspect problem IS the light switch....did you check INcoming power to that fuse?
Old 06-09-2012, 02:14 PM
Go-Kart Mozart
JAR0023's Avatar
Yes. No power on either side of the fuse with the light switch pulled.
Looked at it briefly. Found a kill switch I wasn't told about. Also, have an alarm to remove. I'll be out of town for work all this next week, so I'll save this for next weekend when I have more time.
-J
Old 06-09-2012, 04:17 PM
