MAF Sensor Clip... HELP
Does anyone here have the little metal spring/clip that is on the 5 pin connector of the engine harness that clips into the Mass air flow sensor on a 3.6 that you may be willing to part with? I think that it is the same on late 80's through 993 models. or any ideas where I may find one.
I have checked every local source with no luck. Thanks!! |
