Max Sluiter
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Senior Advisor
BUT if you can't the inner out. you can move the outer plate almost in a circle, there full splines. BUT if your stuck between measurements, then you might have to remove the bar and re-index it to get the desired ride hight. BTW, new shocks effect the ride hight so keep that in mind.
08 Cayenne Turbo |
I cannot get the the inner TB to free up. I can jiggle move the TB up and down and right and left a 1/4in or so but it will not come out. I've sprayed in PB blaster and used Vise-grips with prybars. Is there some inner bolt or clip that needs to be removed?
If you've got the other side out put a long bar in from the other side and drive it out.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
RETIRED
Sway away adjustable spring plates allow for a couple inches of fine tuning.....just sayin'.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Todd
'81 SC |
Home of the Whopper
Remove the spring plate from both sides.
Give either torsion bar a couple of good wacks with a small sledge using a wood drift through the removed torsion cover. Repeat on other side until both bars can move.
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
Did you ever get the car lowered? I need to lower my rear also and looking for any info I can find.
16 VW Touareg 05 Porsche Cayenne S 87 Porsche 930 84 VW Rabbit GTI |
