nineball's Avatar
ducktail fitting help needed
i'm fitting the new duck i bought and everything is great, except for the bottom (above the reflector on my 83). it appears to be sitting a bit too high and i may have to shave off some of the underside where it bumps out and meets up with the rubber strip on the body (under the lid, below the latch). does anyone have a couple shots of a well-fitted duck? particularly i am looking for a couple side views and then one showing how low the back should be (again, just above the reflector).
thanks.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 06-13-2012, 04:48 PM
Oh Haha's Avatar
man, your 911 has come along way Kris!
I was looking for duck pics and found this-
To duck or tail? images please
There are several good photos in here.
Pacific Blue
Wayne
Old 06-13-2012, 05:20 PM
nineball's Avatar
funny how working way too many hours frees up money for car parts isn't it? now i just have to scale back on the work so i can finish installing everything i have.
how was the swap meet this year?
thanks for the link, i'll check it out now.
Old 06-13-2012, 05:24 PM
Oh Haha's Avatar
The swap meet was ok. The weather was crappy but it was nice to see old friends.
Pacific Blue
Wayne
Old 06-13-2012, 05:26 PM
nineball's Avatar
bummer about the weather. i was about 3 weeks behind on my job when it happened and spent 10 hours in the office that saturday trying to finish up for the east coast trip the following weekend (hershey, ac, jersey shore, ac, philly, baltimore and back to home.
i am by no means a body man, so if anyone can give me some pointers here i would really appreciate it. after looking at some of the ducks in the thread wayne posted mine is way off at the bottom. here is what i am dealing with.
this is the part i *think* i have to shave down but i'm not certain.
as it sits now the only thing i have done is to add a pair of washers to the front-most bolts to push up the upper corners of the duck to meet the body. anyone got any ideas?
Old 06-13-2012, 05:39 PM
panos's Avatar
My tail has a very similar lift to it going the same direction...also interested how to fix it!
Old 06-13-2012, 07:40 PM
nineball's Avatar
anyone have any ideas?
Old 06-15-2012, 12:53 PM
Start by taking the hood shock out of the equation. The duck is so light compared to the stock decklid that the shock will push it out of alignment. Then I would try different shim combinations and slide the duck back a few millimeters on the hinges. You may start to close in on the right fit. I would try all of these things before taking the grinder to the tail. Aftermarket tails rarely fit (my opinion) as nicely as a factory tail or decklid. Good luck!
Old 06-15-2012, 01:37 PM
porsher
aston@ultrasw.c's Avatar
I had the same issue and it still looks like a$$
Try shimming the front edge up so it better matches the roof line.
This should lower the rear edge down a bit.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 06-15-2012, 01:46 PM
nineball's Avatar
don't think the strut is causing the problem but i could be wrong. the tail sits down all the way just fine, it's just too high near the license plate.
the leading edge matches the car's line perfectly right now, but i'll try it with another washer or two to see what happens. overall it seems like there is something preventing the tail from going down all the way above the license plate. i have a week to try to get it right before i take it to my body shop to have it painted (and fitted if i can't get it).
thanks all.
Old 06-15-2012, 02:09 PM
Go-Kart Mozart
JAR0023's Avatar
Agree you need to remove the lift strut from the equation. Do you still have the rear engine bay seal on the car? It's cut off in your photo. If you pull that seal does the tail sit on down like it should? How about shine a light in and look through the grill opening to see what's hitting? If I couldn't see what was hitting I'd run a ring of modeling clay around the edge and see where the interference is before I started grinding.
J
Old 06-15-2012, 02:29 PM
porsher
Did you know you can adjust the closed height by threading the latch pin in or out?
79 928 Race Car
Old 06-15-2012, 03:15 PM
nineball's Avatar
J
good point on the rubber seal. pulled it off when i got home tonight and the lid is almost a perfect fit without it. a little more fiddling with it and it should be great, which brings up 2 questions - do i have to have that rubber seal? once i drill out and install the rubber bump stops in the tail will that affect the height?
the latch isn't even installed yet so i don't think that is the problem. the tail is sitting down as far as it will go as it is.
Old 06-15-2012, 06:28 PM
Go-Kart Mozart
JAR0023's Avatar
I don't know on the seal. I've only had my 911 for a few weeks. My work keeps me around wrecked cars and bodyshops.
I'll have to look at the bumpstops on my car. In general bumpstops are used to set the gap and should be adjustable. If the bumpstops you have aren't adjustable I don't see any reason you couldn't add adjustable bumpstops.
If your tail bumpstops are like these from the front they simply thread up into a hole and are adjustable for height.
Old 06-15-2012, 08:33 PM
nineball's Avatar
Ya I have factory pieces. The tail didn't come with anything so I have to transfer everything over from my stock lid.
I'll play with it more this weekend but it looks like I was right and the tail will have to be shaved inside to work with the seal. They designed it so in my mind it has to stay.
Old 06-15-2012, 08:38 PM
Go-Kart Mozart
JAR0023's Avatar
Is your decklid seal fully seated? I know when I got my car home I was standing behind it with the lid up and noticed it was grungy behind the seal so I pulled it out and cleaned. When it went back it )or I tought it was in) the seal stoof up taller than before. Which is my longwinded way of saying make sure the seal is fully seated.
The seal works by compressing. With the seal installed can you push on the ductail and it sit down flush? As mentioned before would having the latch installed help pull the ducktail down?
How does the ducktail compare to your original tail?
Old 06-15-2012, 09:07 PM
nineball's Avatar
The seal was seated all the way, and surprisingly clean under it - not a spec of dirt. I could not push the duck down far enough to make it sit properly with the seal in place. I can't see where the plunger would help based on my last sentence.
Old 06-15-2012, 09:11 PM
Go-Kart Mozart
JAR0023's Avatar
Just looked at mine. Yes, the bumpstops are adjustable. They just thread up into the lid frame. What suprised me is where the seal rubs the decklid. It's not on the bottom edge it's the forward facing edge where the rubmarks are.
Have you tried sliding the tail back? Ignore the fit up top and slide the lid "out" on the hinges. Are the hinges sloted? Looking at your pics again it looks like your lid lower trailing edge could come out a little to pull even with the quarters. You may end up with a wider gap at the top/front edge below the window but that's an easier fix than grinding away at the lower portion.
Someone else suggested adding washers to the upper bolt on the hinge. I agree. I think you raise the leading edge and pull the whole thing back.
Keep in mind that the lid was made from two parts. Upper and lower. If they aren't bonded together just right fit issues show up. Lower has to fit the hinges/latch and upper has to sit in the hole and fit with no gaps. If your lucky these two are the same spot. As you are finding out more than likely they are not. You just have to keep adjusting 'til you find the best compromise fit and then start modifying to clean up the bad spots.
J-
Old 06-16-2012, 07:02 AM
nineball's Avatar
yep, that is the same edge mine is rubbing on (forward most part of the bump out on the bottom). i'm going to reinstall the rubber seal and cover it with chalk to see exactly where it is that is causing the tail to sit up but i think i know the answer already.
the slots do have some adjustment but sliding it back any further causes the end of the tail to extend past the line above the reflector too much. i've already added some washers to bring the upper edge (along the window) to be flush with the body, and any more and it will be above the body.
Old 06-16-2012, 07:26 AM
techweenie's Avatar
It looks like you're down to removing material from the "frame" of the ducktail. I'd focus there. Removing any material from the upper surface disturbs the gel coat and you may be fighting some show through -- forever. So, keep the gelcoat intact as much as possible.
Having said that, it appears from the pix (not certain about this) that the front edge of the lid has too much of an arch. It appears flush in the middle and low at the hinge corners. This may be just the lighting, but if you adjust for the corners, it will ever so slightly change how the lid sits in the rear.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 06-16-2012, 07:42 AM
