Helios59's Avatar
Sudden Drop In Idle Speed
Hi all,
So I just noticed that my warm engine idle speed has dropped from about 900 to about 775 rpm. Came out of nowhere. It's a 1986 w/Motronic, no mods.
Oil pressure and throttle response are unchanged - both are fine. What could have caused this?
I changed from 15W-40 to Motul 10W-40 oil but that was 900 miles ago, and the idle drop just manifested itself today. Nice weather - in the high 70s.
Thanks in advance.
Ray
1986 Turbo-Look Cab
White Gold/Burgundy
Old 06-15-2012, 02:41 PM
steely's Avatar
Hi Ray - one potential cause would be a vacuum leak, so check the vacuum lines to make sure they're connected, and their condition to make sure they're ok. If they're original, they are suspect. Even check the oil cap to make sure it's on. You can search on low idle or vacuum leaks. Let us know how you make out.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 06-15-2012, 05:55 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by steely View Post
... Even check the oil cap to make sure it's on...
+1.
If its on correctly, remove it and if the RPMs do not drop further down, you definately got a vacuum leak.
Who Will Live... Will See
Old 06-15-2012, 08:10 PM
RETIRED
Joe Bob's Avatar
Yeah the cap....my first choice. If it's tight and doesn't drop further even if you block the filler with your hand ...there IS a leak....just not there at the cap.
2012 ML350 3.0 Turbo Diesel
Old 06-15-2012, 09:35 PM
Helios59's Avatar
Y'all were on the money...I didn't have the oil filler cap on correctly.
All is well now.
If only they ALL were that easy!
Ray
1986 Turbo-Look Cab
White Gold/Burgundy
Old 06-16-2012, 11:04 AM
