Sudden Drop In Idle Speed
Hi all,
So I just noticed that my warm engine idle speed has dropped from about 900 to about 775 rpm. Came out of nowhere. It's a 1986 w/Motronic, no mods. Oil pressure and throttle response are unchanged - both are fine. What could have caused this? I changed from 15W-40 to Motul 10W-40 oil but that was 900 miles ago, and the idle drop just manifested itself today. Nice weather - in the high 70s. Thanks in advance.
Ray 1986 Turbo-Look Cab White Gold/Burgundy Last edited by Helios59; 06-15-2012 at 02:44 PM.. |
Hi Ray - one potential cause would be a vacuum leak, so check the vacuum lines to make sure they're connected, and their condition to make sure they're ok. If they're original, they are suspect. Even check the oil cap to make sure it's on. You can search on low idle or vacuum leaks. Let us know how you make out.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
83 911 Production Cab #10
+1.
If its on correctly, remove it and if the RPMs do not drop further down, you definately got a vacuum leak.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
RETIRED
Yeah the cap....my first choice. If it's tight and doesn't drop further even if you block the filler with your hand ...there IS a leak....just not there at the cap.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Y'all were on the money...I didn't have the oil filler cap on correctly.
All is well now. If only they ALL were that easy!
Ray 1986 Turbo-Look Cab White Gold/Burgundy |
