3.6L Engine Swap : 964 vs 993......
So I am preparing to buy a 3.6L to swap into my 1980 SC.
A friend might have a 964 engine for me.. Some people have said that the 964 engines are stronger, but perhaps less powerful than the 993 3.6L's.... Any input is appreciated.
Max ---------- 1980 911 SC 1988 944 Turbo ...dreamin' big... |
the 964 crank though needing a vibration damper has bigger bearing surfaces and so is valued by the track set, these cranks were used an all 964 and the 993Cup cars the top end and engine management of the 993s is a big improvement on the 964 as long as you stick w/ OBD1 cars('95 US 993, '94-98 RoW n/a 993) The 993 non v-ram fits the engine compartment better than either a 964 or 993 v-ram, though all can be fitted '93-94 964 are desirable vs earlier because of several improvements, '95 993 non v-ram is better yet, and a RoW '96 up v-ram probably best of all for street use. I'd avoid US 96 up because of OBD2 issues
Sub"d
A big part of the horsepower difference between the 964 and 993 is because of the improved HEs on the 993. Many people use the 993 HEs (with flipped flanges on one side ) on the street .That exhaust probably brings the 964 very close to the 993 power wise. The variorams still offer a broader torque curve though
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
964 ports 41.5/38 valves 49/42.5 9mm stems DME 2.10 w/ barn door air measure 993 ports 43/39 valves 49/42.5 w/ 8mm stems DME 2.20.1 w/ heated element air measure 993 vram RoW ports 43/39 valves 50/43.5 w/ 8mm stems DME 2.20.1 w/ heated element air measure
993 engine makes more hp and has hyd lifters - so no more valve adjustments. jim
Formerly known as Syzygy
The 993 are a bit quieter mechanically, too, as I understand.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Science is NOT optional
Hydraulic lifters may be a disadvantage?
PCA member since 1993 |
Some change them out to mechanical, but I think that's only those racer types that sustain high RPM running. They might also eat up a little bit of power. I'm just speculating and regurgitating some stuff I think I read somewhere, sometime, so don't take it as gospel.
Thanks for the feedback guys.....
There really doesn't seem to be a clear winner. As far as I can tell the the 964 seems to be stronger than the 993's. Crank and rods especially.... While the 964 lacks the desirable plastic manifold and hydraulic lifters, I have heard that with upgraded exhaust and a tune, the 964 power output will be very close to that of a 993. I'm sure that if I had a line on a good 993 motor, I might be singing that tune, but as it stands now I am looking at a 964 engine for a very handsome price.
Administrator
Getting a good engine is probably more important, ultimately, than whether it's a 91-94 or a 95 or an OBDII motor.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
It's also good to consider weight as part of this discussion. Weight is quite influenced by the flywheel used, exhaust, etc, but the '95 993 in particular is quite light. That said, the low end torque of the VRam puts it in a different class in my book.
69 w 997 GT3 3.6L |
At about 3200 lb curb weight I consider my 993 to be rather portly. That said it is almost as fast as my 1980 SC was with a 3.6
I'm talking about the weight of the engine, not the car. Your 993 was portly, but your engine, if it was a 95, was not (in the context of the 964 and 993 VRam motors).
69 w 997 GT3 3.6L |
