911SC Poor Running & Distributor Signal Phasing Problem
Over the years a numbers of Porsche mechanics have experienced poor running
conditions at RPMs below 3000 and incorrect distributor alignments relative to Z1 on the damper pulley on 911SC engines. This usually results when the distributor has been rebuilt or the green wire replaced. The problem is caused by the incorrect polarity (phasing) of the distributor signal to the CDI unit. Since the unit triggers the spark on the negative going edge of the distributor signal, that edge must go negative in a short time relative to the spark timing. If the signal polarity is incorrect and the triggering signal changes too slowly, the timing will be incorrect relative to the low and high RPMs. The problem is easily corrected by just reversing the pins of the green wire. The ideal method for determining the correct polarity is by using an oscilloscope. The negative going edge must be the faster voltage changing edge of the signal. One can also possibly determine the problem using a timing light by noticing how stable the timing advances as the RPMs increase. Once the signal has the correct polarity, the static timing relative to Z1 and the dynamic timing (timing light) will be correct and the engine will run smoothly and rev very responsively as the RPMs are increased. Therefore, when experiencing a poor running 911SC, one should always check the distributor signal phasing (polarity).
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
Old thread post, I know. Bought a new distributor green wire for my rebuild, with timmy2 ' s advice. Turns out, one I got was pinned wrong. Polarity reversed. Same exact symptoms as stated above. Thanks Loren.
John "Build a man a fire and he's warm for the rest of the day. Set a man on fire and he's warm for the rest of his life". -internet sage |
Thread Tools | |
Rate This Thread | |
