Clutch pedal raises under hard acceleration
anyone experience this?
i noticed when i get the car up to higher revs under hard acceleration, the clutch pedal pushes forward. i step on it and it goes back down and disengages like normal but im guessing i need that fixed!!? any ideas? |
and just what Porsche do you have?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Is this due to a walking crank - excessive crank end play??
I had the exact same thing happen in my Chevy Stovebolt 261.... probably the furthest thing from a Porsche engine that is still out there!
Dave 1985 Porsche 911 Carerra Coupe 3.2 to 3.4L PCA Member- Sacramento Valley region |
Check your transmission and motor mounts.
that's it?
not interesting enough?? lol |
Anytime a motor moves ie bad motor mounts etc. it usually will put pressure somewhere else, or your chassis could be flexing.
Still here
Did you check the mounts ?
Physics. If the pedal comes up the throw our bearing is coming forward. Could be mounts could be tranny.
When these rubber mounts wear, they allow for excessive movement between the transmission and engine assembly and the body of the car. With the clutch cable housing spanning the two, it gets alternately stretched and compressed. It's designed to do this all the time, without you noticing, since those rubber mounts will always allow for movement. It's when that movement becomes excessive that you see and feel it in the clutch pedal. That's why they are telling you to check those engine mounts |
thank you for the explanation. now i know why. appreciate the knowledge. |
