Weekend Mechanic
vulcan300's Avatar
Where does engine compartment light connect?
I'm in the final stages of restoring my 86 Targa and I have a question about the engine compartment light. Where does it connect to? It looked like the wire was meant to route through a hole in driver's side of the engine lid but the connector I hooked to on that side doesn't deliver power. There is a similar connector to the right of the air filter so I'm wondering if that might be the right one. If anyone can point me in the right direction I'd appreciate it.
Thanks!
J
86 911 Carrera Targa
Old 06-27-2012, 02:55 PM
steely's Avatar
See if this helps,
Trunk Light power connector ident
* On Edit - this is obviously wrong, I posted the trunk light wiring - sorry.
I took a look at my 87 and the deck lid wiring goes on the right (passenger side), follows the hinge, and mates to a cylindrical connector forward of the oil filter / about as fwd as the air filter.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 06-27-2012, 04:48 PM
Weekend Mechanic
vulcan300's Avatar
Originally Posted by steely View Post
See if this helps,
Steely, thanks for the info. I have the right kind of connector forward of the oil filter as well. I routed the light wiring to the passenger side because there was a hole and rubber grommet there that looked like it was made to route the light wiring. Could I trouble you for a pic of how the wiring runs from the trunk lid to the connector?
Old 06-27-2012, 09:11 PM
steely's Avatar
sry for lousy pics.
wiring is tucked in lid and exits thru a grommeted hole above hinge.
Is clamped to the hinge and is just played over to the connector.
The connector is in it's own clamp - the wiring is otherwise unsupported in mine.
pass' side eng compartment wall
hinge - grommet not in pic but there
lid
I hope this helps.
Dan
Venetian Blue
Old 06-27-2012, 09:31 PM
Weekend Mechanic
vulcan300's Avatar
@steely, that's awesome! Thanks so much!!
Old 06-28-2012, 05:41 AM
kodioneill's Avatar
It's connected to the l/s tail/parking light wire harness. For it to work I believe you need to have the parking lights on.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 06-28-2012, 06:04 AM
georgew123's Avatar
I click on forum topics that are remotely relating to my car and I must say that this forum is GREAT. "J" had a question that really could only be answered by a fellow owner, so Dan posts the pics of the exact answer... unbelievable how helpful everybody is.
Makes me want to work on my car almost as much as drive it.
Old 06-28-2012, 07:10 AM
Weekend Mechanic
vulcan300's Avatar
I've spent three years working on my car and not driving it. I'm itching to get behind the wheel! There are just a few odds and ends to take care of now and then I'll be motoring!
Old 06-28-2012, 12:46 PM
steely's Avatar
np!, so glad I could contribute. I had a bout of insomnia and thought: just do it :-)
@kodi' - cool tip, I did not know that about the parking lite pwr / harness.
Dan
Venetian Blue
Old 06-28-2012, 03:06 PM
