-   -   Why windshield trim should be a regular maintenance item. (http://forums.pelicanparts.com/porsche-911-technical-forum/686953-why-windshield-trim-should-regular-maintenance-item.html)
wayner 05-13-2014 05:08 PM
Here is a link to a good discussion thread with people weighing in on the merits of sealing versus not sealing.
I've added my own conclusions with my own point added on pages one and particularly at the top of page two.
http://forums.pelicanparts.com/porsche-911-technical-forum/810979-glue-not-glue.html
NOTE
I'd like to leave the glue or no glue discussion for that other thread. It already has some good back and forth/pros and cons discussions building there.
I'd like to keep this one for ideas and evidence.
If you have pictures to add, feel free to contribute those here.
I hope between these two threads we can spare more cars form the carnage...
azhodge 06-14-2014 08:15 PM
OMG!!! these cars are pieces of ****, why do we buy them????
wayner 06-27-2014 05:58 AM
Update:
In the thread above (glue or not) http://forums.pelicanparts.com/porsche-911-technical-forum/810979-glue-not-glue.html
we have been discussing if the seals should be installed dry or not.
After all my experimenting in a combination of 80 to -40 degree weather, my own conclusion is that dry is a risk unless your car is guaranteed to stay indoors during wet weather. Remember, once water gets inside the seal it will take an awful long time to dry out since there is no airflow between the seal.
People don't like the idea of glue though.
Per the advice of Timmy2, this is what I am now using:
3m glazing compound
For those of you who are not ready to pull out your glass but are concerned about adding protection, mask the area either side of the seal, squeeze some in under the seal, and clean up the excess using a rag dampened with mineral spirits. It cleans right up
OR, if you are installing the seals, add a bit inside the track during install.
I think the stuff is the perfect solution, and for those ill fitting corners, it even comes in strips that can be added to the body before installing the glass.
If you ever have to redo the glass for some reason, then cleanup is not so bad either.
azzarule 08-29-2014 06:20 AM
The Parcel shelf in our 72 was a basket case, as was the bottom of each seat well in the rear, luckily we had a friend with a complete parcel shelf and rear seet clip which we used for replacements. A lot of work in a very confined space to cut prepare and weld in the new pieces, but totally worth it of course. Thankfully no rust in the front footwells or around the front windscreen. Rear problems were all based on the rear shield seal. If only the PO had replaced it. There was no indication on any part of the car that you could actually see, that the rust was under the carpet or seat pads.
But during an engine swap, a screwdriver through the parcel shelf from the engine compartment gave it away!
http://forums.pelicanparts.com/uploa...1409320268.jpg
http://forums.pelicanparts.com/uploa...1409320566.jpg
http://forums.pelicanparts.com/uploa...1409322032.jpg
KTL 08-29-2014 07:12 AM
Wow what a mess. I think the car would always have had a very damp, musty smell to it if there was that much moisture creating all that rust?
wayner 09-13-2014 05:24 AM
What is surprising is how much moisture the under padding can hold without the carpet ever feeling damp!
Glaze those seals
Here is how-to
Window Glass Install - Modified Mustangs & Fords Magazine
Hawkeye's-911T 10-19-2015 12:06 PM
One more thing I've added to the "I Must Check This Out" list!
I know it's a little old now but Thanks for your post wayner
Cheers
JB
wayner 10-19-2015 01:08 PM
Thanks for keeping this thread visible
NOTE to anyone reading:
While I agree that a fresh stock seal installed correctly an be made not to leak, why risk it? Why the hesitation to glaze that new seal as added prevention for when it shrinks or heat cycles?
Glaze those seals. It cleans up easily with mineral spirits even years later
wayner 10-30-2015 10:39 AM
My favourite quote from page one of this thread.
Check your seals everyone!
Originally Posted by javadog (Post 7928040)
No, it didn't sit in salt water. It got used in the rain. Lots of it.
That's the point of this thread. There are a bunch of places that water will collect in a 911 body shell if it gets wet. This is made worse when seals fail, rubber gets old, damage is not corrected, etc. Get it wet often enough and it will rust.
Porsche expected its cars to get more servicing than is typically done. I don't mean oil changes but thorough inspections. All the little things that the typical owner ignores completely... They had some long warranties agaist rust perforation but they required that you do an annual (or bi-annual, I don't recall) inspection of the underside of the car and correct any issues.
That still won't solve the rust issues in certain places, as some of that can't be seen without disassembly. They all rust, some sooner than others.
JR
wayner 10-30-2015 10:51 AM
On another thread, here is the debate:http://forums.pelicanparts.com/porsche-911-technical-forum/810979-glue-not-glue.html
and here is my advice
Originally Posted by wayner (Post 8259885)
At this point I have concluded that as Timmy2 suggests, using 3m glazing compound or similar product to act as a flexible, thin, non hardening membrane between the seal and the glass, or the seal and the body is the ounce of prevention that these cars need if they are regularly used and exposed to the elements. I see no down side. It can be cleaned up more easily than urethane sealant, using just mineral spirits, and will adjust with the shrinkage and expansion of the seal with weather or over time.
I see no reason not to use it on the front windshield as well (unless you want to use a more permanent glue to stop movement).
If done properly, you shouldn't have to use any sealant, but I like this stuff just in case
This how-to article was just posted by 3litre on another thread here.
They use the same non hardening 3M glazing compound
I am adding it here for future reference
Lets keep this thread for evidence of why to check or replace seals, and use this other thread to debate if they should also include sealant or not here : is the debate:http://forums.pelicanparts.com/porsche-911-technical-forum/810979-glue-not-glue.html
Duc Hunter 02-23-2016 01:58 PM
Well I live in Florida......where all car get rained on...HARD! And you are never more than maybe 50 miles from the ocean. My 89 is pretty clean (I think), and my new '75 needs a little TLC. I will be going through that one first.....and will be giving both (AND my 996TT) and god once over.
wayner 04-26-2016 04:51 PM
Here is another one.
This time a Carrera 3.2 (galvanized) car.
check those seals!
(fortunately this one was saved and given a second life by its owner...)
http://forums.pelicanparts.com/porsche-911-technical-forum/907880-another-retro-backdate-thread.html
http://forums.pelicanparts.com/uploa...1459306150.jpg
RDM 02-17-2018 08:41 AM
I've had nightmares about this thread for two years. I'm finally pulling my glass to investigate (full thread coming soon, I'm sure), but here's what I found in the front window channel, passenger side.
http://forums.pelicanparts.com/uploa...1518888956.jpg
Just the beginnings of surface rust. Now this car is galvanized, has always been garaged, and previous owners were in Kentucky and Oregon. If rust is happening under those circumstances, it is likely happening in a lot of circumstances.
Seal gap was 2-3 mm on the top and bottom center.
Now, trim refresh, reinstallation, and then on to the Targa window.
Thanks, Wayner for the heads-up!
ghamilton 02-17-2018 01:06 PM
When I got some stone chips in my windshield this summer Hagerty paid to have it replaced.
My shop recommended factory seals, Hagerty said no problem, they even said I could replace the plastic trim even though my shop was able to replace it without any cracking.
And, it was nice and dry behind the seal.
The diff in $ between an OEM and factory is well worth it compared to the cost of repairing rust damage.
BTW Hagerty was great to deal with.
wayner 02-17-2018 01:44 PM
I have had leaks in my new factory oem seals
Seasonal temp swings between +30 to -30 might contribute
A small dab of the 3m product listed above has kept the 2nd installation dry
In fact if you do have an older car and suspect leaking, a dab under the lip of the already installed seal does wonders
The stuff is almost the consistency of toothpaste, never hardens and wipes off easily with mineral spirits
I don’t see a downside to this safety measure. It’s not a glue or urathane
RDM 02-18-2018 05:15 AM
I have two tubes of the 3M glazing compound ready to go when the time is right. You apply after installation? Also, how did you clean the window channel? Someone had a leak before and there's goop in there.
wayner 02-18-2018 07:55 AM
Scroll up to post #50 for an installation video using the stuff
Error on the side of very little rather than too much. Think of it as creating a very thin gasket rather than filling it with goop
A very very light smeer ( almost a lubricant dab, in fact it does lubricator the seal for installation)
The body to seal Chanel, but also the glass to seal Chanel
After installation it allows the seal and glass to react better to thermal expansion/contraction by lubricating but also self healing the waterproof barrier created by the rubber seal
Wipes up easily with mineral spirits even years later
Many people who believe their dry installation remains dry, actually develop what I call micro-leaks and don’t realize it
wayner 02-18-2018 08:22 AM
To clean up someone else’s mess from using some different material, if it’s hardebrd scrape it. If it’s goopy try mineral spirits although if it is some other material then something like goo gone may work better
RDM 02-18-2018 11:38 AM
Just in from taking the Targa window out. Lots of stuff that seemed like gum from under the desks (yes, I teach). I thought it was just old rubber seal, but it's lotsa what looks like plumber's putty. Is that normal?
Koizumi 02-19-2018 03:05 AM
No matter how many OEM windshield rubber seals I get installed, the rubber “drops” below the roofline curvature in places over a short period of time. Not good and very much an annoyance that I can’t seem to ever rectify.
ghamilton 02-19-2018 12:08 PM
A quote from my shop who do a lot of high end cars and customs windows:
"We use a Sika product called Mach-60 to seal rubber to body and rubber to glass. these are used mainly to prevent water from entering car."
https://can.sika.com/en/solutions-and-products/new-products/sikatack-mach60-autoglass-replacement-adhesive.html
NFI
KTL 02-19-2018 12:22 PM
That Sika Mach-60 is basically rubber urethane adhesive. It's for the later style windshields (993-up) that do not use a preformed seal and are glued into the body, then decorative trim applied afterword. The stuff turns to pure rubber when cured. One of 3M's version like the Mach-6- stuff is called Windo-Weld.
We want to fill the void around the seal with a bedding and glazing compound. It's a non-hardening tacky goop that fills the void. The urethane stuff is not a problem, it's just unnecessary because it makes for extra work the next time the glass is removed and replaced
RDM 04-15-2018 11:35 AM
Of course my German neighbor had something to say: "You must do it like the Porsche factory says."
Which is?
http://forums.pelicanparts.com/uploa...1523820651.jpg
So the argument would be that new materials offer a better solution to what they had then.
In the mean time, I am back to cleaning old window cement from the windshield and Targa window channel....
Maybe with benzine!
wayner 04-16-2018 02:54 PM
The current argument that people use is an assertion that the factory didn’t use ANY
I’ve asserted that while you can debate the modern glues, you should use a glazing compound at least
You document FINALLY supports that
Thank you thank you thank you
wayner 04-16-2018 02:57 PM
3m Auto Bedding and glazing compound
