| Registered |
				Need a little more help with my 79 911 air conditiong issue
			So i have a replacement condenser now since mine was quite HOLY and was just looking at a drier. Went to polarbearinc and they only have drier options for two compressors. I have neither. I have a seiko seiki 170psv5.  What is the deal with this compressor. Planning on going to r134.
				__________________ 1979 911 SC 1974 OEM 911 Exhaust and Muffler - Modified to a 2-out Fiberglas Goodies, 17" C4 Cup Wheels Last edited by FinallyGotOne; 07-12-2012 at 06:01 PM.. | ||
|  07-12-2012, 05:28 PM |
| Registered |
			This is my current Drier:  This is my compressor model  Please educate me on why I dont seem to have a normal compressor, and which drier I need. Also, has anyone had any issues converting to r134 running this compressor?
				__________________ 1979 911 SC 1974 OEM 911 Exhaust and Muffler - Modified to a 2-out Fiberglas Goodies, 17" C4 Cup Wheels | ||
|  07-12-2012, 06:00 PM |
| Registered |
			That's a factory style dryer, you can order one right from our host.  The Seiko compressor is just a replacement for the original York, and honestly a great replacement at that.  Porsche 911 & Carrera Air Conditioning - Page 1
				__________________ 2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab | ||
|  07-12-2012, 06:46 PM |
| Registered |
			I don't know which one of those i need.  does it matter ?  would rather the $26 $ one !
|  07-13-2012, 07:27 AM |
| Registered |
			$26 dollar one is the one you need.
|  07-13-2012, 07:38 AM |
| Registered |
			hmm. ok, so what is the yellow plug for. I mean what would go there? and my drier has a 2nd valve on the opposite side at the top. but nothing goes in there either.  I wonder if I have the complete wrong drier on?  Is the drier used to charge the system? or evacuate it or something, is that what the extra valves are for?
|  07-13-2012, 06:00 PM |
| Registered | Quote:
|  07-13-2012, 06:44 PM |
| Registered |
			ok, so we checked to make sure the systemm held vacuum. It did.  We went ahead and added r134 with oil and got to 250 and 40 as far as pressure.  I took it for a spin and it got down to 58 degrees.  We were thinking we'd give it a week and possible add more.  58 was fine for me!  Lifted up the car to check lines just n case and bam had a bright green leak coming out of the ac hose on passenger side just in front of the rear wheel.  Thinking I can use earl fitting and take care of that.  Then I get to go evacuate system and recharge again.
|  07-18-2012, 02:23 PM |
| Registered |
				need to change oil
			from what i understand: 1. you need to purge the oil in the compressor and use new oil for 134 2. new air dryer 3. all new o-rings to all fittings that use them that are compatible with 134.
				__________________ 1975 911S Targa Silver Anniversary Edition Last edited by 47silver; 07-18-2012 at 07:51 PM.. | ||
|  07-18-2012, 07:43 PM |
| Registered |
			Also...be advised..old style hoses can leak right through the side walls of the hose!! This may be the reason so many people have to recharge every year or more often. Bob
				__________________ Bob Hutson | ||
|  07-18-2012, 10:28 PM |
| Registered | Quote:
 Granted, something leaks enough that a recharge is required at least every 2 years. But I am of the personal opinion that what leaks is the o-rings as/when the system high side pressure gets excessive. Shut the car down on a HOT day with the evaporator already at minimum temperature, TXV fully closed, and the heat rising from/through the engine combined with OAT causes the engine lid refrigerant pressure to rise to extraordinary levels, bypassing, temporarily, the various o-ring seals. | ||
|  07-19-2012, 07:57 AM |
| Flat Six |
			wwest:  Point taken re: pressure spikes -> leaking past o-rings; often overlooked.  But in this case I'm pretty sure leak is at hose, not fitting. In front of passenger side rear wheel well is (low-side) hose from evaporator to compressor; no fitting at that location. OP appears to want to cut the hose to remove leaking section and repair/splice with a fitting at that location. Not a good idea, IMHO.
				__________________ Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport | ||
|  07-19-2012, 08:29 AM |
| Registered |
			Doesn't a 79 still have the flare type fittings  ?  I have been told that before you change over to R134, you need to purge ALL hoses/lines and the compressor. Put in new R134 oil, replace the drier and then evacuate and charge the system. Good luck and let us know how it works out as my 79SC needs the same..winter project.
				__________________ 15 year PCA member  1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro | ||
|  07-19-2012, 08:32 AM |
