Rebel911's Avatar
help: Outer rear spline will not let go
The Outer spline will not let go from the swing arm.
I have the torsion bar and swing arm out to the arm is stuck to the torsion bar.
any ideas? all the issues I can find on the search are for inner stuck problems.
thanks in advance.
Some will like it, Many will hate it.
Old 07-14-2012, 11:44 AM
pete3799's Avatar
Heat and a puller worked for me.
Not my picture
Pete
79 911SC RoW
Old 07-14-2012, 12:15 PM
Rebel911's Avatar
How does that work? Drill a hole in the end of the swing arm?
If I put my puller on the arm and the threaded center on the outer part of the arm it seems like they ate the same peice .
Old 07-14-2012, 12:54 PM
Rebel911's Avatar
I have the arms and torsion bars out. The covers Came off no problem. It's getting the arms off the torsion bars.
Old 07-14-2012, 12:56 PM
When I lowered my SC had the same problem, pretty sure they had never been out, I took small wire cable and put a choke loop in cable and wrapped around outer spine then pulled cable thru torsion bar access hole in body. Then attached other end to a 2 inch steel pipe about three feet long. Then pulled it tight, created leverage against my foot on the floor. Then took a two pound hammer and banged on the pipe. It took about 5 minutes a bar to pop them out Good Luck
Old 07-15-2012, 05:12 AM
pete3799's Avatar
There is a plug in the end of the spring plate that needs to be removed.
I don't remember how i got mine out.......i think heating it made them pop off.
Some people have drilled a hole in them and pried them off.
Pete
79 911SC RoW
Old 07-15-2012, 05:56 AM
Chuck Moreland's Avatar
Sometimes the splines do get corroded and fuse into place, draconian methods are then required.
But MOST of the time, the splines can be loosened just by wiggling. Hold the tbar in one hand and wiggle the spring plate with the other.
It may work immediaely. But if you haven't already spent 5 minutes wiggling, do this before considering anything more severe.
Chuck Moreland - elephantracing.com - vonnen.com
Old 07-15-2012, 08:22 AM
