Time To Fit Strut Inserts Vs New Struts ?
Re : 911 Carrera 1988.
Wondering What The Time To Fit Strut Inserts Vs New Struts Is ? I can buy some nice struts with fresh inserts fitted recently OR have brand new inserts fitted to my own struts for the same money. Question is relating to the labour saving ........ ? |
Formerly known as Syzygy
New inserts is less labour than installing new struts. Struts require removal of all the stuff on them - ball joints, tie rods, bearings, brakes, etc.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 07-17-2012 at 08:36 PM.. |
Go Speedracer, go!
Strut inserts is a 1-2 hour job. Pop off wheels, remove top strut mount bolt, replace strut insert, put everything back together. Replacing the entire strut is more involved and requires special tools (ball joint wrench, TRE puller, etc.).
1981 SC ROW Coupe |
Strut inserts is the working part of the strut. Unless something is defective or you are upgrading to a larger caliper spacing or coil overs, there's no need to replace the strut housing.
