midnight911's Avatar
cheap attempt to address sagging c-pillar liner
c-pillar liner is starting to leave its place.
attempting few cheap resolutions to keep it in place...sort of.
which one's do pelicans think the least ghetto and "okay" resolution?
the material i'm using is black 1/32 ABS panel.
1. small strips
2. a panel covering up the whole area
3. something down the middle...
other ideas welcome.
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 07-22-2012, 10:19 AM
motorcop's Avatar
#2 looks best with a large piece covering the whole area. Could even mirror it and put on the driver side so it matches....just my 2cents.
Old 07-22-2012, 11:14 AM
wayner's Avatar
Why is it pulling loose?
My guess is rust in the window Chanel due to leaking seal
Old 07-22-2012, 02:29 PM
too many projects 1983 sc
56 nomad's Avatar
why not try to get some stock material and if you are going to glue it on us that not the felt. jm2c, ben
Old 07-22-2012, 04:14 PM
like #2 but do it up to the seam in the headliner and big enough to tuck in the rubber. If you do a good enough job it should almost look like its suposed to be like that
Old 07-22-2012, 06:56 PM
redstrosekNic's Avatar
+1 on option #2. It will look fine if you take your time.
Dustin
Old 07-22-2012, 07:03 PM
