Brorag
Rear A/C condenser in spoiler tail
Has anyone successfully mounted the rear A/C condenser in a regular spoiler tail?
the car is not a turbo, and the condenser dimensions are 28 1/4" x 10 3/4". The condenser is larger than the original, and extends past the air intake area: ![]() The tail is stock spoiler pkg: ![]() My intent is to funnel all intake air through the condenser, blocking open space around the installation. I've also replaced the front condenser with one of the hosts units, and found that the front condenser fan is frozen up. When I dis-assembled it, I found both mounts for the motor brushes burned: ![]() Ordered CCC038 Ametek 3.3 Inch 12 Volt DC Motor from for $56 from electric motor warehouse--will mount via mods in tech forums Last edited by Brorag; 07-30-2011 at 08:47 AM.. |
The simpler, MUCH simpler, thing to do is mount 2 12 volt radiator cooling fans on the outside of the engine lid, under the spoiler, to force (more) airlfow through the rear condensor just a sit is.
Or... Why not cut a larger opening in the engine lid above the condensor AND use the appropriately sized radiator fans. Run the fans at half power, in series, with the A/C enabled, but at full power when the compressor clutch is engaged. I would also disable the HORRIBLY inefficient squirrel cage blower assembly at the front. As a matter of fact my guess would be that with the 2 new rear fans operational the front condensor/blower would not be required. |
Member 911 Anonymous
Place a fuse on the hot lead of that front Condensor motor, you are lucky it did not catch on fire
![]() WW, question, will not opening the lid in my case with a Turbo tail cause the air to flow less over the rear condensor and make the air find the least amount of resistance? I was going to open up my rear lid but was scolded not to. Wondering??? His Carrera tail actually fits only over the OEM inlet.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Brorag
in-line fuse, absolutely
I'll absolutely add an inline fuse to the front fan--found that the front fan had been previously unnplugged.
So, sticking the too large (in current position) rear condenser into tail is possible? I also like the idea of putting fans between tail and condenser. Must cover spaces around condenser, though; most air will go around condenser rather than through it. I might first get out the duct tape and cover all the open spots around condenser to see if all the changes would be worth the trouble. wouldn't the fans get in way of air flow at speed? Last edited by Brorag; 07-30-2011 at 08:48 AM.. |
There's a factory plug-and-play fuse kit for the front condenser fan. I'm sure out host sells them, or can get one.
1984 Targa |
Brorag
Yes, there is a Santa.
Brorag
parts ordered
Product Quantity Sub Total:
________________________________________ Fan Wire Harness Kit with Relay SKU: FRH 1 $34.90 ________________________________________ SPAL 10" Slim Fan-Push Version SKU: 30100374 2 $123.80 ________________________________________ Subtotal: $158.70 Tax: $0.00 Shipping (Ground (US Cont)): $14.90 Total: $173.60 JayCorp Technologies JayCorp Technologies |
Brorag
fans too large
After screwing up the order, I called SPAL USA and asked for recommendation for fans to blow through an A/C condenser for a space 8.5" X 27.75" (opening in engine lid) Was told to use these.
Will swap monday--prob get 3--SPAL said I can use these on 1 relay. 30100393_SPEC Last edited by Brorag; 08-19-2011 at 02:33 PM.. |
Brorag
10 lbs in 5 lb sack
Skip this entry for install--read if thinking about making more room for ait in engine compartment: I tried to make room but there is no room to be had--would have to trim heat exchanger plenum to fan, and the modification caused the condenser to bump against the motor fan shroud. I put it all back the way it was.
Had to make room for air flow, so I lowered condenser into eng compartment a smigin to allow better air circulation through condenser. ![]() any cooling has to fit into this space ![]() Before: condenser fited as close to engine lid as possible ![]() After: I adjusted brackets so that condenser rides lower and slightly rearward of original position ![]() Three small fans should now fit into the space provided, and blow downward into condenser. Wiring kit includes relay, and other stuff to tie to the A/C circuit. There is also a provision for a fan override to run the fans constantly or without the A/C running. When complete, all air will be forced thru condenser and into eng compartment, with no side leakage. Last edited by Brorag; 08-28-2011 at 03:52 PM.. |
Brorag
Update--fan installation
Rcv'd 3 SPAL 7.5" fans and went to work:
installed piece of 1/2" X 3/4" L as shown: ![]() ![]() tie to center wing mount for stifness and bow: ![]() use spacers to assure proper fit: ![]() ![]() ![]() route wiring toward fuse block on driver side--3 fans mounted: ![]() I'm beat--happy hour--beer................... |
Brorag
A/C blows cold
OK, I finally got this thing back together, and it works:
I installed 3 of these fans. After finishing and testing, I think 2 would have been enough. ![]() part # 30100393 Weight: 2.5 lbs. VA14-AP7/C-34S FAN (7.5)" 7.5" Straight Blade Low Profile Fan / 12V Pusher low profile fan line this fan for oil cooler applications. Sealed waterproof/dustproof motor. Each fan individually balanced. Wired fans to run off relay triggered by A/C compressor clutch wire, so fans go on/off when a/c compressor runs. Used this relay kit: wiring in this photo routed above and behind fans after install. ![]() ............installed relay in the engine compartment fuse and relay panel. Since my car is a cab, there was no rear window fogger relay, but the wiring harness is standard across all models, so the relay plug was present. If you have the fogger relay in place, find another high amp source for 12 volts I mounted the Spal relay in the fogger relay position, and used the fogger relay plug to tap 12 volts: ![]() ...........wrapped sides of A/C condenser so that all air passes through it. There is enough space around fans so that the engine fan can draw cooling air when the A/C fans aren't running. ![]() results: I left the A/C on and engine running at idle while I tidied up, then checked passenger compartment. It was noticibly colder (it was cold!!!). Previously at idle and low speed the A/C would stop cooling due to inadequate air across the rear condenser; this fixed it. What I would do different:
Before sealing up the edges, did you run it without the tape to see how much air was actually escaping?
1984 Targa |
Brorag
Scott,
yes--good bit off to the sides, but given the fan over kill, I think it would have still been effective. I'll probably paint the metal tape--looks a bit gauche......................... Last edited by Brorag; 08-31-2011 at 08:42 AM.. |
Nice job!
1984 Targa |
Are the RPM specs of the motor you are noting above the same or better than than the stock Bosch motor? |
Brorag
That doesnt answer the question.
RPM of new fan - 2350. RPM of Stock Fan - ?? If you are using the same parts (other than motor) then there will need to be a noticeable increase in RPM's to actually make a difference... Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Do you have a tail?
How does this impact fit of the condenser against the deck on a car without a tail?
The stock motor is TWICE the speed of 2350RPM Ametek
In that case it makes NO sense to do this. You are degrading performance by 50%. Unless you are just doing it because you are cheap and want to rig it to save a few dollars.
