Question How to Adj Points and Mixture
I was wondering how to adjust the points and the mixture on my 74 911. The motor is a 2.7 and I am stuck with her for the next few months until I rebuild my 3.0. When I had the car smogged the technician said that my car had way too low numbers and that it does not have enough gas in the fuel mixture. He said that giving it more gas helps cool the engine, is this correct, and how do I do it?
Jeff Caron
Old 05-22-2002, 12:55 AM
Author of "101 Projects"
Wayne 962's Avatar
Your mechanic sounds like he shouldn't be working on Porsches...
Adjusting the mixture can only be done with a gas analyzer, something that he should definitely have. Not sure what the points have to do with smog? Can you give more details?
-Wayne
Old 05-22-2002, 01:52 AM
I just need to adjust the points, I placed in a new pair and kind of threw them in. The car runs but I would like to do it right.
Jeff Caron
Old 05-22-2002, 09:37 AM
Early_S_Man's Avatar
Porsche Crest
Jeff,
the following thread has all of the pertinent data for your distributor ... which is the same as the '72-'73 911T used.
distributor lube...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-22-2002, 09:47 AM
Thank you
Jeff Caron
Old 05-22-2002, 09:49 AM
