I was wondering how to adjust the points and the mixture on my 74 911. The motor is a 2.7 and I am stuck with her for the next few months until I rebuild my 3.0. When I had the car smogged the technician said that my car had way too low numbers and that it does not have enough gas in the fuel mixture. He said that giving it more gas helps cool the engine, is this correct, and how do I do it?
Jeff Caron |
Author of "101 Projects"
Your mechanic sounds like he shouldn't be working on Porsches...
Adjusting the mixture can only be done with a gas analyzer, something that he should definitely have. Not sure what the points have to do with smog? Can you give more details? -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I just need to adjust the points, I placed in a new pair and kind of threw them in. The car runs but I would like to do it right.
Jeff Caron |
Jeff,
the following thread has all of the pertinent data for your distributor ... which is the same as the '72-'73 911T used. distributor lube...
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thank you
Jeff Caron |
