Manual Window regulator
I have a 79 911SC and replaced the electric window regulators with Manual Parallel arm regulators. The pivot on the manual regulators is good. After install I had a problem raising the window and half way up the gears would slip and make a clicking noise(the gears slipping). I can pull the window up with no problem, I made sure that the bolts at the rear of the window frame are not the 16mm ones and even with the window frame loose I still have the same problem. I cleaned and replaced the slides that go into the frame that attaches to the bottom of the window and the window channel is not binding.
Help!! I don't want to go to a window strap but at this point that is my only option, and I don't have any hair to pull out, I'm already bald on top!
dog
Old 08-04-2012, 05:16 PM
ROW '78 911 Targa
timmy2's Avatar
Window Regulator Qs. '76 manual crank. Help? Schematic
Manual Window Regulator Repair
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-04-2012, 11:09 PM
Thanks, but it didn't help.
The pivot pin has been replaced and outside of the car it cranks nice and smoothly. I even cleaned the plastic slides and keeper washer and springs.
Does anyone know if the ribbon spring is suppose to be in tension with the Window up or with the window down?
Thanks for any help!
dog
Old 08-05-2012, 07:44 AM
dimps8's Avatar
Dog I found this after searching for regulator pivot posts, I'm going through the same thing, HarryD mentioned....
You want the spring at full tension when the window is down and minimum tension when up, that way the spring helps you to lift the window and the weight of the window helps to wind the spring.
It makes sense.
Damon Harris
66 912 coupe
Old 08-05-2012, 07:58 PM
i have some new manual window regulators give me a part no. i may have one for you cheap
Old 08-05-2012, 10:08 PM
Any chance that you or anyone has manual window regulators .
Rocco
Old 10-23-2015, 04:42 AM
carrerarsr65
i have one i had to replace just need to tack weld a pin ,let me go to storage ,i'll send you a pic
Old 10-23-2015, 05:56 AM
