I own a 1980 Euro 911SC, the vin# is 91A0130707. The two previous owners had the car registered and titled (TX and NC) as a 1979. I also registered the car in RI as a 1979 to keep things simple. Something that bothers me is the import tag on the drivers side door pillar. It says the car was manufactured in 1978 (see attached pic). I was thinking about trying to correct all the documentation to officially register the car as a 1980.
Can someone please run a CARFAX report on the vin number to get me started? I did a search in the archives and found a good post that SeaDweller originated on 6-11-2001. Thanks!
John Adams 1980 ROW 911SC |
Carfax can only be used on 1981 and newer cars when the Vin #'s were standardized to 17 digits. Interestingly, I also have a 1980 Euro located in NC, where the previous owner thought it was a 1979. That's the way it was registered. My Vin is 91A0131074.
-Rob 1980SC |
Rob, did you register it as an 1979 or 1980?
A lot of cars were physically manufactured in the calendar year prior to the year of their actual model. How else could you buy a 2002 model in the fall of 2001, which is very common. My '87 Carrera was made in Sept. of 1986.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Richard, I agree with a 1 year difference but the import tag says 1978 for the year built v.s. a 1980 vin #? That's the problem.
Senior Member
Look at it on the bright side... you qualify for "no smog check" one year earlier!
Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
John,
I registered mine as a 1980. I think all I did was tell the lady at the DMV that it was a 1980. That's it. I no longer have a build date sticker or import tag on my car, so I don't know when it was made. I can only go by the VIN which says it's an '80. -Rob 1980SC |
As an aside, it my my understanding that, by definition, a model year can have only one January in it. As a result, a model year can start in (say) February 1978 and end in December 1979.
