hi Todd,
- volt gauge = to check if your charging system works as it should. I had a broken regulator before and fried a couple of components without knowing (charging at 18V instead of 14V). - afr gauge (air/fuel ratio monitor): this is to protect my full engine rebuild investment. After spending 15K, i don't want to damage the engine by running too lean or something else. After i installed it, it was immediately obvious that my CIS was running like crap...hence the swap to EFI. cheers, Jan |
Thanks wreckah and Trackrash.
Trackrash - do you have a name or link or something where you found that gauge? Quote:
For my 82 SC I’m looking for a sportier, more aggressive exhaust. I have a stock setup besides the test pipe. My mechanic recommended M&K. What do you guys think?
Rennshift + Wevo Coupler
SSIs w/ 2 in 1 out sport muffler of your choosing (ideal for street) 16x7/8 Wheels and 205/225 good tires Momo Prototipo w/ eccentric spacer All maintenance/wear items These changes have made the biggest difference to my SC. |
It'll go faster with an SC 930-10 after you lighten it...mucho.
Did vanos ever state his goals?
Changes that I have made that I would definitely recommend:
1) 7&8 x 16 Fuchs 2) Karsten spring 3) 930S steering wheel 4) H4 Headlights 5) a/c delete I would also recommend the following--original owner already did these prior: - exhaust (B&B tri-flow headers and 2 in / 2 out exhaust - strut brace - F/R sway bars |
I plan on “backdating” my ‘82 SC to an early CIS set-up with matching large port heads (among other mods). My Stock ‘82 “dies” around 5500 rpm and it drives me nuts, if I want big block torque I’ll drive one of my pushrod V8 cars… |
I found some cloth Recaro's w/ headrest that are very light...put some Pascha on the center sections so looks good too. They wear well also...have had them for some years now. |
For me, there's no better cheap and easy mod for an SC than plugging the decel valve. Having the engine drop RPMs slowly is not cool lol.
Prior owner of my 82 Targa
Plenty of power to redline Ported intakes and runners to 36mm Replated Nikasil's w/ JE Pistons - effective static CR 9.7:1 Elgin SC330 cams timed at 2.0mm SSI's with Dansk Sport 2/1 |
I think location should govern your mods somewhat.
I tried a few of the tricks for SCs incl. 2021 cams, SSIs and CR CDI box. Definitely made a difference but it’s not the “silver bullet” power wise. Most of what I have around me in close proximity are freeway on ramps. For that, I think an SC is inherently undergunned and the exhilaration of a turbo would be A-plus. I took ~150lbs of weight out, refreshed the suspension (and increased TBs), added 9x16s to rear and drove to California. The exhilaration of flowing through corners and being able to use all pro forma 200hp all of the time was priceless. That’s the hook for me. That I could comfortably and reliably cruise all the way back home fills me with admiration for CIS (I’m ashamed to say). I’m going to try and continue to take more and more weight out on the sly, without changing the cars appearance as a stock car. If my ship comes in, I may think engines or a stable mate but it’s getting pretty good as is. |
| All times are GMT -8. The time now is 01:16 PM. |
