Throttle Bellcrank on Transmission: Bushings won't fit
Hi Folks,
I bought the bronze bushings as a replacement to my plastic bellcrank bushings that had disintegrated. I have tried all I can to get these pushings into the bellcrank however they seem to be 2-thou to big? Has anyone else experienced this issue?
1975 Widebody 911 3.2 Euro |
Yep! Had the same problem a couple of months ago. My original bellcrank was still in pretty good condition, so I put it back on and threw the bushings in a box. Didn't want to hassle with return on a cheap part. Perhaps you could alert PP to the problem.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
perhaps putting them in a freezer to allow some shrinkage would help ??
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
Not a chance, they are way too big!
Schleprock
Which ones did you buy, the Weltmeister or the Pelican?
Porsche 911 & Carrera Cables & Controls - Page 6 I recently installed these on a bellcrank and they fit good. I was surprised, because I too had the same problem as you several years ago when replacing the plastic bushings on my '87 bellcrank. The bronze ones didn't fit (Weltmeister I think) so I just stuck the old plastic ones back in there until I obtained some new plastic ones
Kevin L '86 Carrera "Larry" |
Pelican Parts - Product Information: 914-423-211-00-M105
I'm pretty sure I ran into this same issue a few years ago. After a back and forth with Pelican customer service, I was able to press the bushings in using a vice. They didn't look or feel like they'd go in, but they did; albeit with a very tight fit!
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Grand Am/IMSA Data Guy
I did plastic ones yesterday. They were too big also. I used the vice to force them in. If the bronze ones are the same diameter as the new plastic ones, I doubt they would go in
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
Same here about five years ago. I brought the brass bushings and the bellcranks to a machine shop and asked them to turn down the bushings to a tight, sliding fit into the bellcranks. Had to do the same thing on both bellcranks (trans and engine.....brass bushings on both). No problems since. You might be able to do it in your basement with a drill and file. After you put everything back together again (engine console was a looong reach) don't forget to confirm full travel of the throttle plate.
Howard '76 911S '53 Nash (!) '01 Audi TT '82 GPZ-550 |
I had the same problem with those Canyon bushings several years ago on my SC.
I chucked them up in a drill press and "turned" them down a few thou' with a file as suggested above. Have been working great ever since. Cooper |
ROW '78 911 Targa
Interesting, both sets of brass bushings I bought from pelican for the throttle bushings in both locations (tranny and engine) slid right in. Different tolerences from the factory perhaps?
^^^^^^Mine fit too.......
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
