too many projects 1983 sc
help decoding engine number
hi ,
still need a little more clarification so bear with me please....i am looking at the purchase of a motor, can anyone help with the id?do targas have different numbers from coupe? i know sportos do etc. the stamped number on the case is 6117***...is this a targa or coupe block ? i see 2 different references and of course they differ. ben Last edited by 56 nomad; 08-08-2012 at 04:48 PM.. |
for a 1971 911T the engine could be one of 4 different types, and totally independent of body type. Basically either USA or ROW (Rest Of World), and manual or sportomatic; so two versions for each market. Any of the four types could be in a coupe, a Targa or a Karmann coupe; the body type does not matter.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
According to my reference, you will not be able to tell from the engine number is the block was specific to a coupe or a targa as both body styles used engines from the same number range.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
how would you be able to to tell if a block was within the range of the build on a certain car..did porsche put casting dates on blocks..the block i am looking at numerically has a 300 or so difference from my block (later/larger numbering). could/would it still be correct for my car? thanks , ben
probably be easier to track if you had the 2 threads about the same thing in just one thread...Just sayin...if the highest number is 6118119 and yours is 6117**** doesn't it make sense that it is in your series ?
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
wouldn't the block with the higher number be built after the block with the lower number...are there casting numbers located on the blockthat would be cross reference to the vin? Last edited by 56 nomad; 08-08-2012 at 04:56 PM.. |
thanks to all for your time and info...thread closed. ben |
