83 911 Production Cab #10
JJ 911SC's Avatar
Rear Fuse/Relay Panel Delete
Anybody done that?
I got a 83 Cab with no defrost, no wiper and the heating is backdated so the only thing left is the Test Port but since I'm going PMO EFI + TECgt soon, I don't think any of it and would like to remove it.
Who Will Live... Will See
Old 08-17-2012, 07:11 PM
brads911sc's Avatar
you will likely need the battery and switched power for your ignition and fuel management. wont you?
I deleted all the relays but added an modern fuse block in its place with 4 battery and 4 switched to power all this stuff. your wideband 02 will need both battery and switched power as well.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 08-17-2012, 07:22 PM
brads911sc's Avatar
pic
Old 08-17-2012, 07:25 PM
JJ 911SC's Avatar
Yes, I'll need switch and unswitch 12 V. I don't have the kit yet but I think the TECgt has their fuse on board.
I know the rear blower was on a switched circuit so I will take that one from there. I used the test port to do my idling adjust but wont need it next year
Do you have pic a bit zoom out?
Old 08-17-2012, 07:34 PM
brads911sc's Avatar
pic
here are a few...
Old 08-17-2012, 07:39 PM
JJ 911SC's Avatar
Thanks Brad
With the TEC, the Coil and distributor are gone (and all the electronic go between the PMO stacks so I'm hoping that the only thing left in that quarter will be the fuel filter which may be switch to a glass type filter.
I'll definitely post before and after pick in the new year.
Old 08-17-2012, 07:53 PM
brads911sc's Avatar
will look great! look forward to pics.
Old 08-18-2012, 06:53 AM
