Northern Motorhead
wildcat077's Avatar
Header install,heat concern ???
Hey guys,
In the process of installing some Fabspeed headers and i have a concern regarding the hard plastic oil hose that goes from the bottom of the oil tank
to the engine oil cooler.
It seems that there is not a lot of clearance,just wondering what other people have done regarding this issue.First thought is to get some high temp exaust wrap and insulate the hose and the closest header pipe.I'm able to pull it up a few inches,will that be enough with the heat wrap to be safe ?
I'm also considering some stainless braided hose to replace the hard plastic one.
Tie raps are just temporary ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 08-20-2012, 06:17 AM
Tom '74 911's Avatar
I have Fabspeed headers w/heat on my 3.6L conversion. I have successfully been using the standard "S" hose like you have shown, but have been nervous about its longevity. B&B makes a hard line that replaces the rubber "S" hose - something that's on my list to buy. . .
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 08-20-2012, 06:58 AM
schumicat's Avatar
isn't that line made of rubber rather than hard plastic? if it feels like plastic it means it has lost its suppleness and is brittle (probably from decades of heat, not your recent upgrade). I would replace it.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 08-20-2012, 08:20 AM
Northern Motorhead
wildcat077's Avatar
That hose is on my next purchase list from Pelican ...
Tom,how close is your hose to the header pipes ?
Anyhow,i have a heat resistant sleeve and a 15ft roll of 2 inch high temp exaust wrap on order,hopefully it will keep me going for my last two events of the season !
Cheers !
Phil
Cheers
Phil
Old 08-20-2012, 09:10 AM
I'm not exactly sure, my engine is on a stand in my garage at the moment, not in the car. . . Probably 2" to 3"? I attached the hose so it was bent UP instead of sagging downwards to give it more clearance which made me feel better. I just ordered B&B's replacement metal line for when my engine goes back in for piece of mind.
Tom
Old 08-21-2012, 06:36 AM
Northern Motorhead
wildcat077's Avatar
I just picked up a new "S" hose from the dealer today ... low and behold it is rubber !!!
Just when i thought it was made of hard plastic ... lol
Got my car "tech'd" today at my local tuning shop for this weekend's 3 day track event and the boys in the shop said i should be good with a high temp sleeve on the hose and the hose pulled up for extra clearance.
Going to dump the oil and replace it tomorrow when my sleeve and heat tape arrive.
How did i live without headers for the last three years,my car sounds like a poor man's GT3Cup car now
Thanks for the feedback guys !
Cheers !
Phil
Cheers
Phil
Old 08-21-2012, 08:52 AM
Senior Member
If you are concerned, wrap it with heat shield material. Thats what we did on mine and it works great.
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB
Old 08-21-2012, 09:05 AM
DG624's Avatar
Why not use a ceramic coating like Swain or Jethot?
Swain Tech Coatings | Industrial Coatings | High Performance Racing Coatings | Technical coatings to solve problems of heat, wear, corrosion, and friction
Old 08-21-2012, 09:20 AM
