Power difference guesses? 73T
Hi all, I bought a 73 911T a few months ago, great car goes well.
I always thought for a T it was really strong, but as the previous owner had the engine rebuilt at great expense (I've got massive stack of invoices) a few years ago I figured it was just newer parts working well. However I recently found out while sifting through the volumes of invoices that while the engine is a matching numbers engine, when it was rebuilt they changed it to higher compression with new pistons/cylinders to 9.8:1. I'm not a fan of putting old cars on dynos so not keen on that, but was thinking you guys would have some good educated guesses out there as to what that would do to the power output? cheers |
Does it state what cams were put in it?
72 911 Although it is done at the moment, it will never be finished. |
AutoBahned
divide the 2 compr. #'s
same displacement? CIS or MFI?
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
I rebuilt my 73 T MFI Coupe as follows:
E cams MFI Pump worked over by Gus @ Pacific Inj to E spec. Throttle Bodies rebuilt to E spec by Matt Blast @ Eurometrix 85mm cylinders from EBS Reno J & E pistons @ 9.5:1 Replaced the smaller T stacks with E stacks. MSDAL6 Therefore, I must be makin about 285hp..........Errrrrrr, probably around 165-175. Really happy with the engine & it's power, on ramps are a blast. Steve 73 911 T MFI Coupe, Aubergine
Opps, wrong pic.....911 not Diesel
Its a carb model (euro). According to all the paperwork, same displacement and cams etc everything else was standard, although carbs were retuned to suit the higher compression...
What does dividing the two compression numbers achieve? Does that mean 7.5/9.8 x standard HP? thanks! |
Max Sluiter
The percentage change in power should be similar to the percentage change in compression ratio.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
ok...that's a big uplift then, 130% of standard HP = approx 170HP (assuming it had 130 to start with). I used to have a 73E and it does feel stronger than that but I figured that was because the E was a bit tired...maybe not...
Max Sluiter
I am not sure what the actual correlation is. It is non-linear but in the region we are talking it may be about 1:1. This is empirical, not based on strict physics, so it is an approximation.
Generally each additional point of compression increases the power output of a motor by 6%. So assuming you had 130hp to begin with at a CR of 7.5:1, going to 8.5:1 increases the output to 130*1.06 = 137.8 hp. Going from 8.5 to 9.5 CR is another 6% or 137.8*1.06 = 146 hp. Going from 9.5:1 to 9.8 is about another 2% power increase, or 146*1.02 = 149 hp.
Or you can calculate it by the equation for Otto cycle efficiency:
AutoBahned
I wonder if the original CR of 7.5:1 is correct - seems low
1973 "T" w/Solex-Zenith carbs (per Tobias Aichele) = 7.5:1
1972/73 "T" w/MFI (per Spec book) = 7.5:1 1973.5 "T" w/CIS (per Spec book) = 8.0:1
Keep the Shiny Side UP! Pete Z. |
All cars are different, put it on a dyno.
AutoBahned
aha - mine is/was a 1973.5 "T" w/CIS
![]() thanks
Ok, so I take my stock 73 911 MFI T and come back with E cams, E stacks, E Throttle Bodies, MFI pump re-built to E spec, 85mm cylinders & 85mm J&E 9:5.1 pistons.
Stock T = 130hp Stock E = 165hp Do the engine pro's think this engine is making over 165hp? Steve 73 911 T MFI Coupe, Aubergine |
Gosh I hope so. Porsche lists the 72 911E with 165HP stock with 8:1 compression ratio.
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
Now if it makes you feel good that someone states your car has 165 based on calculations, then feel good.
