Woohoo! Car is now MOT'd!
Not so good, need a new steering wheel as the rim appears to be broken. Not sure what to do with that. Do I stay original or go aftermarket. |
Fleabit peanut monkey
Also....
In the far upper corner in the front fender well there are several pieces welded together. I found that debris can get packed up in there and stay wet and I had a wee bit of rust at the weld point when I pulled the fenders for a repaint. You can't really see the spot because of the confined space. Aside from the overkill job of pulling the fenders, I would just spray up there in the corner liberally with a garden hose and flush any debris out. Surely the stuff, if any, has dried but may help going forward. ![]()
personally i love the 930s wheel. that's what i have in my 83SC. Pelican Parts.com - 930S Steering Wheel you can even get a little crest to put in the middle.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Have one in my '79. Congrats on the car and passing the MOT.
Ray H. 1979 911SC Coupe 2000 986 |
I'm leaning towards the Momo Prototipo. I'm liking the balance between form and price!
arry911
I have a momo wheel on mine and it looks good and the cars easy to drive with the smaller wheel.My cars a 1982 sc ,looks the same.I think you might find its india red very close to guards red.Well done for saving the car you will love it with the roof off!
PhD on Pending Projects
Love that photo!
![]() I have one of my son when I was working on the top mechanism... he just took the sunglasses and tried to drive the car ![]() ![]() He is growing and learning to love cars and work on them ![]() ![]() Best of luck on the project! It is coming along great.
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
So the little lady is now tucked up safely in my garage.
The first drive was eventful, maybe picking the car up and driving it for the first time in the dark wasn't the best plan! I spent ages trying to figure out how to adjust the passenger mirror (manual, not electric!) I found that the fuel sender didn't survive after all and only works below half a tank and then intermittently (what's the range on an 85 ltr tank?) I don't need a stereo because that engine note is gorgeous The road surface on the M25 is awful The right pedal is addictive I can't see the speedo between 40 and 80mph (momo prototipo wheel is a bit small, so I've rotated the speedo and then rev counter to match) The dials are lit by a candle I'm guessing (yes I've found the dimmer and no it didn't make a blind bit of difference!) The gear change is lovely, I just don't like the lack of centering spring or the fact that the gear knob always seems to be out of reach! (Rennshift on the way) The upgrade list is growing, I know I didn't have a load of cash before, I don't think I ever will again! I managed to do a few jobs over the weekend. I've modified the gauges so I can see them in the dark, I've used EL wire inside the gauge fed by an inverter near the fusebox. The only other quick change was fusing the dash lights and starting to build a replacement fuse panel. All of my rough running issues seem to stem from cracks in the original panel. Shouldn't take too long to build up the panel as Fred cook has kindly shared his fuse panel instructions which has given me a massive jump start. |
Weseeeee911
Congrats on your new ride. I'm enjoying your project, thanks for posting.
