Fan ratio for an SC?
Anyone know what a stock SC fan drive ratio is? I'm guessing around 1.5:1 but i'm sure someone here knows the accurate number.
Gary R. |
Fleabit peanut monkey
The 78 US 930-04 / US California 06 / Euro SC 03 all had 1.81 to 1.
Direct from the little Tech Spec book. |
How's the car?
Figured it would be you answering that Bill..
![]() Few hours on the celette, new hood, bumper, lights, headers, some bondo and paint, and she will be like new!
Gary R. |
RETIRED
What....Bob is invisible? Funny looking, yes....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Schleprock
Some of us still like you.
More light reading to beat the subject to death. Engine Fan Drive Ratio Do a search Gary, you lazy..........
Kevin L '86 Carrera "Larry" |
Gary,
The ’78-’79 911SC ratio is speced 1.81:1 with the largest (134 mm) crank pulley and a ~84 mm fan split-pulley. However, it has the smaller 226 mm fan. With the small fan, the air flow is specified as 1380 liters/second at 6000 rpm crankshaft speed. Best cooling is using this pulley arrangement with the (earlier & later) 245 mm fan. This is speced as 1500 l/s @ 6000 rpm with a 127 mm crank pulley. Using the (~80 mm) fan hub from a 5-blade fan on the 245 mm fan and your 134 mm crank pulley, you can increase the ratio a bit more than 1.8:1 and get air flow in the (perhaps) 1700 l/s range. These are very desirable combinations for a street 911 where one needs increased cooling of the engine machinery (cylinders & heads) at driving speeds. For track use, your small fan (even at the earlier 1.3:1 ratio) and the Rubbermaid Solution is ideal. This almost does away with the need for a front cooler. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
