-   -   BRAID 17" Fuchs Replica Wheels. Input Requested. (http://forums.pelicanparts.com/porsche-911-technical-forum/700074-braid-17-fuchs-replica-wheels-input-requested.html)
BRAIDusa 09-19-2012 07:20 AM
Thanks guys. Great input. I have asked the factory to consider putting in to production the following:
WIDTH OFFSET
7 +49 --- front and rear early 911, 914, early VW
8 +30 --- front 911, front 911 widebody, front 930, rear 911, 914, 944
9.5 +19 --- rear 911, front 911 widebody, front 930, rear 930, 944
11 0 --- rear 911 widebody, rear 930
PcarPhil 09-23-2012 05:29 AM
WIDTH OFFSET
Very cool.
The 7" +49 is a 911R spec offset. Of all (4) of the sizes listed that will probably be the best seller - mostly to VW folks. Early 911/912/914 guys will enjoy having a 7x17" wheel option to fit non flared cars.
The 8x17 +30 may also fit the narrow '69-'77 911 cars front and rear. The rear will be close and will require some negative camber to fit. The front may require a small spacer or removing the metal strut dust covers and replacing with the rubber VW covers.
The 8&9.5x17" combo for 911 SC and 3.2 Carreras will be a sweet setup. The front may require a small spacer or removing the metal strut dust covers and replacing with the rubber VW covers. The rear may require shaving the spring plate bolts, some negative camber, and heavier rate torsion bars depending on ride height. This combo may be the best seller or slightly behind the 7" wheel in sales.
The 8&9.5x17" combo for 930 cars should be an easy fit.
The 9.5&11x17 combo for 911 widebodies and 930 will be sweet. It'll be a tight fit front and rear but for those folks that are serious about fat Fuchs style wheels these will be the answer to wanting this style wheel at an affordable price. As long as pricing is reasonable I'll be in for a set or two of these in RSR finish.
Another interesting combo - for a late 930 use 8" ET +30 front wheels and 11" ET 0 rear wheels with 235/40 front and 275/40 rear tires. That should be an easy fit with the later style front hubs. Rear spacers would be removed (or a small spacer could be used).
island911 09-23-2012 07:15 AM
Originally Posted by $ Short (Post 6971693)
What Bill V said.
Also would someone explain semi-forged.
Kurt
Originally Posted by BRAIDusa (Post 6973307)
It's a proprietory proccess but they wont tell me how they do it. As far as I can tell the center and back rim are one forged piece and the front rim is a spun shell. Regardless the end result is light and strong.
So then, a welded section?
side note; I'm surprised that more people aren't asking about construction (considering the history of compromised imitations)
GaryR 09-23-2012 07:49 AM
Originally Posted by Elombard (Post 6942487)
Its a small market but 9s and 10s or 11s that fit an SC or carrera converted to turbo flares would be nice.
Exactly what I will be needing at some point, market just got a little bigger!:D
Amochosto 09-23-2012 05:39 PM
As large a wheel that will fit in an unmodified 1984 narrow body Carrera and I'd definitely give it some major consideration. What kind of price point are we thinking here?
brentrussell 09-23-2012 10:49 PM
RSR Fitment and Finish
Yes I would be keen for 17x9.5/17x11 for RSR widebody in RSR Finish.
I don't think people asked about the process as most people know the Braid are the better of what is available aftermarket.
Brent
Originally Posted by Kaefer (Post 6992439)
Very cool.
PcarPhil 09-24-2012 05:19 AM
Here's an example of 911 widebody 9.5&11x17 fitment from Brent's build thread.
Rear 11x17 ET 0 wheel with 315/35R17 tire:
http://forums.pelicanparts.com/uploa...1307226125.jpg
Front 9.5x17 ET +8 wheel with 255/40R17 tire:
http://forums.pelicanparts.com/uploa...1307226045.jpg
The 9.5" ET +19 wheel proposed by Braid will move the front wheel closer to the inner fender by 11mm, allowing a bit more outer clearance for a 275/40R17 tire and slightly better scrub radius.
Nice setup Brent!
PcarPhil 09-24-2012 05:30 AM
Here's another example of the 9.5&11x17 fitment.
This example has the exact offsets that Braid is considering. 11x17 ET 0 and 9.5x17 ET +19
http://forums.pelicanparts.com/uploa...1177024921.jpg
PcarPhil 09-24-2012 05:58 AM
GaryR 09-24-2012 06:01 AM
Kaefer - Is that with no spacers on the blue car? What tires are those on the unpainted widebody?
PcarPhil 09-24-2012 06:09 AM
According to the link that's correct, no spacers.
I believe the tires on the unpainted car are Nitto NT05.
GaryR 09-24-2012 06:25 AM
Thanks, i'm thinking I want to go 315's and 245's on my car, seems like 275's would make the slow speed steering pretty heavy, no?
PcarPhil 09-24-2012 06:30 AM
Tires are a personal preference. For widebody cars I've seen 235-275 up front and 275-335 in the rear.
Personally I like running tires on the narrower end of the scale. Lighter weight and usually smaller diameters.
BRAIDusa 09-24-2012 07:38 AM
Yes, I believe there are welds involved. But these are not "compromised imitations" of course. Just ask Carlos Sainz.
http://sphotos-b.xx.fbcdn.net/hphoto...53787317_o.jpg
BRAIDusa 09-24-2012 07:41 AM
No numbers on these yet but if one looks at the prices for 15" and 16" and extrapolates............................BRAID USA
BRAIDusa 09-24-2012 07:47 AM
Here's a thought: would anyone consider a three piece wheel with hidden screws? Should look just the same. Advantage 1: easy custom offsets. Advantage 2: might actually happen.
Disadvantages : ???
PcarPhil 09-24-2012 07:50 AM
Disadvantages : ???
Sounds good to me. Currently the best (and most expensive) 17" Fuchs style wheels are built this way.
myamoto1 09-24-2012 09:20 AM
Disadvantages : ???
Absolutely! Price might be the only downside (from a sales standpoint).
not_hans_stuck 09-25-2012 11:04 AM
ditto for the 9.5 and 11x17 on SC's. But also with an inch of space for big brake calipers.
Hal
totle 09-26-2012 02:49 PM
Originally Posted by jsveb (Post 6942345)
for a 930: 9 and 11" would be awesome!
+10
