turbo offsets 9" & 11" and 8"&9" Carrera offset Carrera offsets must clear Turbo calipers or large calipers. I like the RSR finish or option for polish lips and custom colors.
Paul- I chatted with you about this a few years ago. 17's would be a no brainer. I would probably order 2 sets right away. Getting proper race rubber on 17's has been a dream of mine. I'm limited to only one tire manufacturer right now, on very old wheels. I do not trust Fuchs anymore since finding a crack. It would open a whole new experience for early cars.
Thanks for all the input. very encouraging. I think I might have some news next week.
17x8 front with ET +30mm 17x9 rear with ET +17.7mm |
Ruf Classics are good wheels (made by Speedline) but they are seriously heavy. ~28 lbs is my recollection. Similar sized 17 in. three piece racing wheels like Fikse, Kinesis are less than 20 lbs each. +8 lbs per corner of unsprung weight is a huge amount.
I have no doubt that welded aluminum wheels can give some serviceability --some tough miles-- but how many compared to a one-piece forged Fuchs.... IOW, yeah, there will be compromises. Welding aluminum means creating a 'heat affected zone' along the weld. That area will be softer than the parent (forged/spun) material. ...and Aluminum has no stress endurance limit to design to, so, you will likely have fewer cycles (miles) with a welded solution. (assuming the same loading.) OTOH, if they give say 60%+ life cycle but cost 50%(-) of the fully forged, then it's a win. |
The construction of Fuchs wheels has been well documented. -no welds :)
Lindsey Racing, CarsRUs (Gary Stratton = "sonjay" here on Pelican) and Trudesign have been making welded Fuchs for a very long time. They have held up to the abuse of track driving/racing quite well. Quite a few Pelicans have these wheels and i'm not sure we've seen a problem yet.
I'm not saying island is wrong about the welding. I'm just saying in practice the wheels are holding up pretty good. Braid's rally wheels indicate that too. |
http://www.teamilluminata.com./Shop/...09040small.JPG http://www.teamilluminata.com./Shop/...09043small.JPG He still uses the wheels. Can't say how much of the car is still in circulation. |
Here is a picture that could help with offsets/ width ideas.
http://forums.pelicanparts.com/uploa...1348843441.jpg |
Wow... Looks great Al :eek:
Cool picture Chad. What is the zero end of the tape measuring from? Hub mounting surface I assume?
Thanks, Kevin |
I'm a customer for 9x11x17 in RSR finish!
BRAID want me to estimate initial sales. I think they are going to insist I purchase all of the first run. Who else is interested and at what specs? I know it all depends on price etc but they should be consistent with our 16" offering plus an inch in dollars ;) |
I cant take credit for it, I got it from Dave at TRE. It helped me figure out my wheels/tires from my race car.
| All times are GMT -8. The time now is 03:01 PM. |
