Which return spring should I have???
I have a 1981 UK 911 SC engine and i'm trying to figure out if I have the correct return spring. i have a vertical orientatied short throttle return spring, but not sure if its a) the correct spring and b) whether I should have this return spring aswell/instead:
911-110-165-02-M100 Pelican Parts - Product Information: 911-110-165-02-M100 my short spring connects to the throttle body and butterfly the one above appears to connect to the pivoting part of baseplate any pictures of what it should look like would be much appreciated. cheers guys Nathan |
That spring connects to the underside of #1 or #2 air runner and goes to the accelerator console on top of the engine to return to idle. You need both
Bruce |
blimy! its quite stiff to open the throttle up by hand using just the one spring i have already!
it rotates very easily with no spring - so may be i have the wrong spring. any chance of a pic? so i can see how it connects? |
