jmshepard's Avatar
carrera throttle linkage issue
I am trying to use a Carrera Intake on my SC. I have run into a problem with the linkage.
The intake manifold and throttle body are both from a source that is different from the throttle linkage plate. It could be a mismatch of year groups, but I can't determine this from the PET illustrations.
I have swapped out the linkage/bell crank plate on the engine case with a Carrera version, however the linkage that came with the TB seems to have the socket for the ball joint on the wrong side of the push-pull rod. I would appreciate some guidance on this one.
Thanks,
Jim S.
I say we take off, and nuke the site from orbit. It's the only way to be sure.
2009 Cayman
Old 05-31-2008, 03:31 PM
purplehaze's Avatar
Jim -
I think you can make this work.
Just take the piece on the right of the throttle linkage plate (the one with the ball pointing to the right) - and flip it so the ball is facing the other way.
If however, that's the side that's solidly secured to the shaft - you'll have to cut and weld the linkage piece 180-degrees.
Good luck!
Glenn
Glenn
87' 930TT
Old 05-31-2008, 04:02 PM
jmshepard's Avatar
thanks Glen! I'm on it.
Jim S.
2009 Cayman
Old 05-31-2008, 04:31 PM
I ran into the same problem on my car. FortunatelyI had this one that I suspect is a carrea piece in my drawer.
This should work.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 09-07-2012, 08:19 AM
In the first picture the lever to the right is backwards, the ball needs to be inside and the levers near parallel.
Bruce
Old 09-07-2012, 09:51 AM
